WHealy
12-29-2003, 08:53 AM
Anyone have any words of wisdom on how to remove the highlighted interior trim piece. It's right between the rear seats and the rear door.
Thanks in advance
Thanks in advance
View Full Version : Assistance with removing an interior trim piece WHealy 12-29-2003, 08:53 AM Anyone have any words of wisdom on how to remove the highlighted interior trim piece. It's right between the rear seats and the rear door. Thanks in advance Genom 12-29-2003, 09:45 AM You have to lift off the seat (pull up carefully and open the plastic fastener holding the 2 metal loops in the top back part) and then just pull it off. Some light plastic clips and the seat are all that hold it in. WHealy 12-29-2003, 01:23 PM Genom, Thanks for the help. Foudn that you pull the rear seat bottom right up from the two fasteners with little effort. This then exposes two bolts holding the rear seat back. Loosen these and then the seat back can be raised off to more clips near the top. Then it can be lifted out. Of course then you can remove this trim piece. Thanks so much. Genom 12-29-2003, 08:51 PM Ooops. Forgot about the bolts. Sorry :D Bet ya tugged at that sucker for a while saying "Dammit genom, I thought this was EASY?" :D Zoom2X 12-29-2003, 09:18 PM How much ya wanna bet that he wanted it out so he can paint it blue? MEGAREDS 12-29-2003, 11:39 PM Originally posted by Zoom2X How much ya wanna bet that he wanted it out so he can paint it blue? LOL. I had the same thought. I'm surprised the highlighting in the photo was pink and not Winning Blue. By the way, WHealy -- love the engine bay... WHealy 12-30-2003, 07:30 AM Come on. That's not a fair bet! Bet how many pictures I'm gonna post on it. Now that's tougher! But we all know it will be a high number! Oh and Genom not i wasn't cursing your user name. Only because I didn't remmeber what it was. No seriously, thanks for your help in making the world more blue! WHealy 12-30-2003, 08:50 PM Originally posted by Zoom2X How much ya wanna bet that he wanted it out so he can paint it blue? Zoom2X, In case you didn't see it, you were obviously correct. (http://www.rx8club.com/showthread.php?s=&threadid=17601) Thommino 09-17-2004, 08:58 AM I don't understan How remove rear seats? Can you help me? Thanks WHealy 09-17-2004, 09:55 AM I don't understan How remove rear seats? Can you help me? Thanks Thommino, I PM'd you the following info. From memory and a reply to a post just today, I believe all you do with the bottom cushion (the part you sit on) is pull up where your knees bend over it (front). This releases two metal clips easily. Then I think you can pull that portion out. Once removed, I believe you will see two bolts at the bottom of the seat back. Remove these. Then slide the seat back up with little effort. Then it comes out once you slide the seat belt though the slit in the “guide” attached to the seat. Hope that helps. robertdot 09-17-2004, 08:34 PM I don't understan How remove rear seats? Can you help me? Thanks I think you need to buy a Shop Manual. You can get it from Canzoomer, Trussville Mazda, etc. Thommino 09-18-2004, 02:21 AM Thanks I understand how remove them. |
