Is this correct? Please help.
Old May 20, 2009 | 05:04 PM
JOLIET WANKEL's Avatar
Xboxgametag:Chafed Banana
the pictures are listed below. should this hose be plugged into this valve? should this green plug be plugged in? what is the purpose of this hose? what am i plugging in by connecting the green plug?
thanks
Old May 20, 2009 | 05:10 PM
Post the URL of the pics directly to the post, some of us don't use myspace.
Old May 20, 2009 | 05:47 PM
i don't think i can. the pics are on my myspace, not somewhere else.
Old May 20, 2009 | 05:50 PM
myriadshalaks's Avatar
rot8ing
right click. save pic as
upload it here as attachment using the button that looks like a paper clip.
Old May 20, 2009 | 06:00 PM
HWK11's Avatar
Lighting Yellow
i cant even see it with myspace cuz your pictures are set as private
Old May 20, 2009 | 06:05 PM
you should be able to see them. checked my privacy settings just now. everything's wide open for public viewing.
Old May 20, 2009 | 06:21 PM
before: Is this correct? Please help.-before-copy.jpg
after: Is this correct? Please help.-after.jpg
Old May 20, 2009 | 07:31 PM
rot8ing
looks right now. not sure about the tube though.
the green plug is the sensor for your vacuum. looks right. The hose, i think, goes to the secondary vacuum inlet.
can you follow it and see what else it connects to?
Old May 20, 2009 | 08:31 PM
Jon316G's Avatar
Grasshopper
That is correct JOLIET WANKEL.
The green harness is plugged into the VFAD solenoid and the hose is now connecting the solenoid to the vacuum chamber (which is that 'barrel' device you see in the "before" pic).
If you were to follow past the vacuum chamber, you should have a check valve and then the hose connects to a nipple behind the throttle body.
cliffkemp
Dec 24, 2024 10:48 AM
mdl0209
May 23, 2019 05:46 PM
Evan Gray
Nov 24, 2015 01:00 AM
GranTouTou
Sep 30, 2015 06:11 AM
Stubbs
Sep 27, 2015 04:06 PM
