DRL Diagnosis
Old May 18, 2009 | 12:15 AM
byez's Avatar
DRL Diagnosis
Driver side DRL is not working yet both high beams work, meaning it is not a burnt bulb.
Where should I begin? E-brake? Relays?
Old May 18, 2009 | 12:18 AM
Likely the DRL module..it's a bunch of relays that aren't replacable easily ( soldered)
The module is under passenger side dash.....
Old May 18, 2009 | 11:48 AM
byez's Avatar
Is there a DRL module for each headlight side? Can only one side stop working with a DRL module?
Old May 18, 2009 | 12:03 PM
The module has separate relays for each side...they fail......the module sucks.......
Old May 18, 2009 | 12:19 PM
shaunv74's Avatar
Power!!
Made specially for Canada no doubt...eh?
Old Jul 9, 2009 | 11:27 AM
byez's Avatar
What color is the module and does it have any specific markings?
Old Aug 7, 2009 | 09:56 PM
byez's Avatar
Still working on this problem but now the high beams stopped working on the passenger side. It is not the bulb because I tried replacing the bulb with a brand new one.
I measure voltage to the high beam connector and got around 3-4 Volts. Symptom of a bad DRL module or something else?
Dokuji
Nov 1, 2016 02:51 PM
nAVEL
Apr 19, 2016 08:49 AM
nowakm99
Oct 9, 2015 07:10 AM
Str8lineJKing
Jul 22, 2015 04:19 PM
FrostyRotary
Apr 26, 2008 10:24 AM
