Question for Coils.
Old May 17, 2009 | 01:11 PM
turbovtec's Avatar
Question for Coils.
How can i see if they are in good condition or not? Or if any of them is messed up?
Old May 17, 2009 | 10:49 PM
rx8cited's Avatar
Senior Member
DIY on testing OEM coils
Old May 17, 2009 | 11:19 PM
No need to test them.
when you get high rpm misfires so constant that even changing plugs dont help, its time to replace them.
their life range from 5K miles to 35K. depends on your luck. im dead serious.
Old May 18, 2009 | 07:48 AM
dillsrotary's Avatar
jersey fresh
Also I notice my idle would jump around as the coils life depleted. Once 4 new coils were on it sat solid.
Old May 18, 2009 | 09:35 PM
turbovtec's Avatar
thats exactly the problem i am having. RPM keeps jumping around from 1.2k to 7.. sometimes 5 nd back up. i read that thread and i don't really understand how to see if they are good or not.
Old May 18, 2009 | 11:44 PM
unless ur coils are garbage and/or plugs are all bad, no way your idle would dip below 700 rpm.
Its better to check your engine.
Old May 18, 2009 | 11:48 PM
turbovtec's Avatar
Its fine when I'm at normal idle. I turn on the AC during Idle and it just drops to 500.
Old May 19, 2009 | 12:16 AM
Check your TB.
Old May 19, 2009 | 01:40 PM
04RX8man's Avatar
Rotary Powered Countryboy
yeah TB and prob would not hurt to do coils if it's been awhiel also!
Old May 19, 2009 | 06:10 PM
turbovtec's Avatar
almost 30k miles.. whats a TB? sorry guys I don't know this stuff.
Old May 19, 2009 | 10:41 PM
Throttle Body
Old May 19, 2009 | 10:50 PM
rx8cited's Avatar
Senior Member
Originally Posted by nycgps
Check your TB.
So how does one check the "flip thang"?
Old May 19, 2009 | 10:57 PM
You need a computer, and a program support the proper data logging.
or do a simple test.
hold your clutch down, Rev ur car like there is no tomorrow and let go, usually, the rpm would "stay" at around 1100+/- rpm for maybe 2-3 seconds before your idle goes to 810. but if it doesnt, its bad.
Old May 19, 2009 | 11:16 PM
rx8cited's Avatar
Senior Member
I did the simple test a few days ago and it passed. Does the clutch really have to be in if the shifter's in neutral?
If the test fails, what is one supposed to do to fix it?
Old May 19, 2009 | 11:21 PM
Thats good to know.
Yes sir.
Replace it, I think it cost like 3-400 bux ?
r-enzyme
Oct 1, 2015 01:27 AM
NotAPreppie
12
Sep 24, 2015 03:22 PM
Sheldon24
Sep 21, 2015 04:53 PM
titaneum_grey
Sep 6, 2015 10:21 PM
iwannarun
Sep 6, 2015 01:37 PM
