Alignment help
Old May 15, 2009 | 07:54 AM
RawrX8's Avatar
Grocery Getter
Alignment help
Need some type of alignment help. Tein S Techs, Koni Yellows, 275 tire. I got minor rubbing in the rear atm. Anyone have a base alignment spec I can use to take with me so I get in the ballpark?
Old May 15, 2009 | 11:56 AM
TopGear8's Avatar
mkuhnracing.com
Your running the same size tire and wheel as me, and I'm lowered on coilovers. Even before I got my alignment I didn't have a problem. But now I am at a -1.8 camber in the front and -2 in the rear and it is not even close to rubbing anywhere. I would say if you have at least -1.2 in the rear you should not rub at all.
Old May 15, 2009 | 11:58 AM
RawrX8's Avatar
Grocery Getter
When I saw your post I was like oh **** I forgot about Carrot top. Right on ill take those numbers to the tire shop today. Thanks man.
Old May 15, 2009 | 06:41 PM
RawrX8's Avatar
Grocery Getter
So im now at -1.8 front and -2.1 rear. We went -1.5 in the rear and when he pulled it off the rack it was rubbing. Back up and went -2.0-1 and it settled at -2.1 so we called it good. So far so good. Im sure it will scuff during tire flex. Im either going to go ahead and fender roll or im going to climb under there with a 1 inch belt sander and take off 1/4 material. That will be way more than enough and **** it, never selling the car anyways.
Old May 15, 2009 | 07:09 PM
roll your fenders.
over -2.0 in the rear = kiss the inside of your tires goodbye.
I'm running 19x10 wheels in the back with 275 Toyo T1R tires and I have no rubbing. (also on Konis + S-Techs)
Last edited by Jedi54; May 15, 2009 at 07:40 PM. Reason: because pdxhak is a picky mofo!
Old May 15, 2009 | 07:30 PM
pdxhak's Avatar
Official Post Whore
Unless you guys are running the same make and brand of tire, comparing the size could be irrelevant. Also more negative camber in the back than the front promotes understeer.
Old May 15, 2009 | 07:40 PM
pdxhak: updated my post. (check the reason. )
Old May 15, 2009 | 08:24 PM
TopGear8's Avatar
mkuhnracing.com
Are you running a 40 sidewall? It seems like you should have this much of a problem in the rears.
Not always. I'm running -1.8 in the front and -2.0 in the rear. RB sways front and rear, and megan coilovers. Along with 275's all around, and at every autox event, no matter how dry the course is, I always get oversteer, bearly any understeer, even with the rears at full soft, and fronts close to full stiff for the coilovers.
Old May 15, 2009 | 08:46 PM
pdxhak's Avatar
Official Post Whore
Well I did say promotes vs. it does
As you pointed out there are many factors that go into it. Your setup counters what your alignment promotes
Old May 15, 2009 | 08:50 PM
pdxhak's Avatar
Official Post Whore
nice :D
Hopefully soon I will replace the 255's that run to wide up front for my setup
Old May 15, 2009 | 09:37 PM
RawrX8's Avatar
Grocery Getter
I swapped the rear wheels to the front and there is no uneven wear going on. Tread is down from the countless hard driving (over driving the car into slides) and drag racing.
Like pdxhak said, every tire is a little different than most. 275/35/18 Eagle F1 All Seasons. This was the best I could do to prevent scuffing.
I am rolling fenders here soon, when no idea. I put the car through its paces when I gave angrybumblebee a ride. I 'think' I heard it scuff once. But the more I think about it, I think it was his *** chewing a hole in my seat when the car was 4 wheel drifting out of a corner.
I abuse my car like a red headed step child. Sorry topgear
ps. So many haters about camber. bastards.
Old Jul 18, 2009 | 01:42 PM
nationapn's Avatar
FL No One Will Align my RX-8!
Does anyone know anything about the rx-8 being any different than other vehicles when it comes to alignment? I've taken my rx-8 to both Firestone and Big 10 Tire, and both places told me they couldn't do the alignment (after they put it up on the rack)....it had something to do with not being able to measure the height on the right side? They said something to the effect of a 15" measurement, and that my best bet would be to go to a dealership. They also mentioned something to the effect that the computer wouldn't accept the numbers they were putting in.
Any ideas? Clearly, I know little about alignments...but I would really like to avoid paying twice the normal alignment cost by doing to the dealership.
Old Jul 18, 2009 | 02:26 PM
Clearly they are idiots
Go somewhere else where they have a clue
If there are any racers or performance shops nearby...call them and ask who can do alignment to spec locally
Old Jul 19, 2009 | 05:34 PM
tiltmode43's Avatar
OMGITM!
What the hell?
I've had my 8 aligned at numerous places without any problems. A buddy of mine who recently aligned it commented on how easy it was, actually.
redrx82015
Aug 17, 2025 01:10 PM
gwailo
May 14, 2024 06:57 AM
blainezoomzoomrx8
Sep 9, 2017 08:29 PM
Solidtrance
22
Sep 4, 2015 12:47 PM
thewatcher101
Jul 27, 2015 09:44 PM
