Florida heat. dash gauges vs aftermarket gauges
Old May 11, 2009 | 09:41 PM
Z0oMzo0m's Avatar
Well Florida summer is here and the temp. is around 90 so far. I had some aftermarket gauges installed in my car last year around august. so the heat was gone.
I am seeing my gauges go past 200 (oil temp, water temp) they were sitting around 215! i have never seen them go that high. Is it the hot weather and/or should i be looking into somthing else? i see they gauges drop down back to about 185/190 but they tend to go up quick if i have to bring the revs up.
The gauges on the dash stay the same, but i dont think they will move until damage is done..
The car i have to say runs better.. it has a smooth idle, and seems to get up and go better. I do have MAZSPORT COOLING MOD, and throttle body bypass. but Waiting on A.P map.
Old May 11, 2009 | 10:28 PM
Stock water gauge moves beyond 235 F, correct me if wrong.
I dont depend on it tho. I have Defi water temp, oil temp and oil pressure gauge installed.
Just keep an eye on it and dont let it go pass 230, u will mostly be fine.
Old May 11, 2009 | 10:34 PM
Z0oMzo0m's Avatar
ok, i didnt think there really was an issue. since it goes up and comes back down. its just havent seen it go over 210 before. but its now 90 degrees outside with humidity.
Thanks,
Old May 12, 2009 | 10:17 AM
04RX8man's Avatar
Rotary Powered Countryboy
yeah i believe the stock water gauge is arond the 230 mark mine did it the first day i moved into florida last may and went a little bit past halfway then i stopped and shut it off while the fan ran for about 20 minutes
Old May 12, 2009 | 12:29 PM
if your oem gauge start moving, you're pretty much heat soaked already. Be VERY careful driving at those temps, you don't want to push your car too much.
Get yourself the Racing Beat gauge pod and you'll be set.
Old May 12, 2009 | 03:14 PM
Z0oMzo0m's Avatar
yeah i have sport comp2 with racing beat gauge pod. my dash gauge never moves when it gets warm. It sits on the white logo. and never changes
I was saying my water temp and oil temp on my aftermarket gauge was sittin about 215. i havent seen it go that high, but it has been the first time we were actually hot outside. since i installed the gauges back in august
Old May 12, 2009 | 03:15 PM
should have seen some of us in Vegas last year. Mazdamaniac and I were upwards of 230 at one point.
Old May 12, 2009 | 03:21 PM
04RX8man's Avatar
^wow 230 would scare me.... I hate hot days cause i'm always watching my stock dash gauge(since that's all I have) and if it starts to move(which it hasn't in a yr) past norm..it's gettin pulled over and shut off...
Old May 12, 2009 | 03:24 PM
pulling over and shutting off isn't always the best move though. Keep going at an easy pace (little engine load) and get some more cold air in that thing.
230 was scary though. We were in Vegas for the annual meet and Saturday morning was when we all chose to go for a leisurely drive. We ended up outside of Vegas going up some hill and got stuck in a ton of traffic. Ambient temps were about 112° and all of a sudden we've got bumper to bumper RX-8's (can we say... NO air flow?) Temps started going up QUICKLY.
As soon as we put some distance between the cars and got moving we were doing better. Problem with places like Vegas (unlike FL) is that there's NO HUMIDITY. It's amazing what a little more water in the air does for cooling. (or lack of )
Old May 12, 2009 | 03:25 PM
z0om zoom: you should look into either an upgraded radiator or the Mazmart water pump. Those can really help out
Old May 12, 2009 | 03:58 PM
04RX8man's Avatar
yeah that's the prob around here is that the only time i ever had trouble was in traffic so the only option wasto pull off and let it cool off...i basically live in the middle of the city so traffic sometimes gets hectic....
BHR radiator and mazmart waterpump....is a good upgrade from what i hear!
Old May 12, 2009 | 04:22 PM
Z0oMzo0m's Avatar
hmm il look into them, thanks!
also a good point was brought up, do not turn your car off right away if it startd going up in temp. If you do that it might explode some hoses. its better to move steady turn your heater on adn pray it drops!
Old May 12, 2009 | 04:55 PM
04RX8man's Avatar
^ oh yes i know this anytime that it's hot out even if it's not overheating or anything i always let it run for awhile at idle to move some coolant through with the fan running.....don't want heat soak
cliffkemp
Dec 24, 2024 10:48 AM
JimmyBlack
273
Feb 10, 2020 10:23 PM
projectr13b
RX-8 Racing
20
May 14, 2016 06:25 PM
FubarI33t
Sep 28, 2015 08:45 PM
drlubell
Sep 26, 2015 11:58 PM
