Throttle Actuator problem
Old May 8, 2009 | 05:21 PM
So here's my problem
Reset ECU....throttle works for about 6-8 seconds..car throws a solid CEL...and throttle is limited to maybe 5% opening. There is no code for the CEL( that my scanner can see anyway), and when the PCM is reset the throttle works as above again. If I try to restart without a clear the throttle is limited as above
I've checked the wiring harness for the throttle, tried a new throttle body, tested the harness to the MAF, TB, MOP....fuses and relays are all good....tested the harness to the relays.
I'm almost ready to put a frag grenade under the hood and pull the pin
Any ideas what can cause an instant CEL and limp mode?? I think it might be the MOP....but the current one tests OK
Old May 8, 2009 | 05:38 PM
MazdaManiac's Avatar
The FSM says that DBW fail-safe is cause by an improper APP sensor output (as I mentioned to you in the PM). The TP sensor can do it too, but you said you swapped the TB already (though that does NOT eliminate the harness).
Old May 8, 2009 | 05:44 PM
Checked the harness..it's OK..I'm checking the APP sensor voltages now....let you know if that seems OK
Strange thing is the car did this a year ago..and the MOP was the problem
No Cel thing is a bit strange...
Old May 8, 2009 | 05:47 PM
Well, there are two APP outputs and the behavior you are witnessing my be just a glitch in the output of one.
Old May 8, 2009 | 05:55 PM
tubingchamp's Avatar
What mawd bug?
So you actually got your car started then Dan? :D
Old May 8, 2009 | 06:16 PM
APP sensors tested OK
Scoped the Throttle control tested OK
Old May 8, 2009 | 06:17 PM
They both tested perfectly normal
Old May 8, 2009 | 06:18 PM
Starts..idles great....no throttle
Old May 8, 2009 | 06:20 PM
What mawd bug?
Totally stinks.
Good to hear the idle is smooth, though
Old May 8, 2009 | 06:23 PM
Yup..that means that when I figure this throttle thing out the rest is working properly
STINKS bad right now though
Old May 8, 2009 | 06:26 PM
Brettus's Avatar
Boosted Kiwi
Do you have a list of all the codes that will throw it into limp mode ?
Old May 8, 2009 | 06:28 PM
Nope....Problem is there is no codes set ( with the Scanalyzer anyway) I have a Service manual and didn't see that list??
I thought that MOP, ECT and DBW problems were the only ones that caused limp mode...and none of those codes are coming up...and everything I can think of scopes/checks out
Old May 8, 2009 | 06:41 PM
Brettus's Avatar
Boosted Kiwi
I have never seen a list - just thought it would help you eliminate the possibilities if you had that info .... Perhaps Mazda could help with that ???
You have more than one version of scanalyser don't you ? Try the USB version if you haven't already ...
Old May 8, 2009 | 06:45 PM
Suppose...problem is I find them less than helpful usually. Maybe if I could talk to a high level tech guy I could get some answers. The usual run of the mill techs have a difficult time with even the service manual stuff ( no slight to anyone who is a tech on here...nothing personal..just my experience with Mazda Canada)
Old May 8, 2009 | 06:48 PM
Brettus's Avatar
Boosted Kiwi
PM that guy 'tecknics' I think his name is - he is a Mazda tech & seems to have quite a bit of knowledge ...
Old May 8, 2009 | 06:50 PM
YA. Kevin definitely has a clue.....maybe he can ask around to the tech line as well
Old May 8, 2009 | 11:17 PM
Still looking for ideas
Old May 8, 2009 | 11:48 PM
wow,
dan send me an email. i will ask the question to the two master techs i know on monday.
but something on the inside of the passenger compartment? connections to the pedal itself? i saw a note on a failed acc pedal assembly recently. but odd, way odd..
Old May 9, 2009 | 12:41 AM
The APP sensors seem to be perfect?
Ask them what can cause throttle failure in 6-8 seconds..
Old May 9, 2009 | 05:44 PM
Afternoon.....
Old May 10, 2009 | 03:00 PM
phone call is in.
Old May 10, 2009 | 04:38 PM
^ Thanks man....
Old May 10, 2009 | 09:23 PM
zoom44's Avatar
dan- no throttle at all or partial up to a certain rpm?
Old May 10, 2009 | 09:29 PM
zoom44's Avatar
nm re-read first post.
what about fried o2 sensor? could possibly make the pcm think its in an overtemp situation so it limits throttle.
orrrrrrr........ what about weird signal from eshaft sensor? thinks its running high rpm sitting still- triggers low throttle.......
Old May 10, 2009 | 09:39 PM
I've got a dealer mechanic ( one of the good ones ) coming over Tuesday night with the OEM Scanner......maybe there is a code that isn't showing up in the Hymsters Scanner
It's really a PIA...if I could get a throttle response..I could tune it and make it to the track day on the 29th in my car
RevMeHarder
Jun 1, 2026 02:30 PM
JimmyBlack
273
Feb 10, 2020 10:23 PM
Prescription 8
Non-Rotary Swaps
117
Feb 14, 2018 12:07 PM
nowakm99
Oct 9, 2015 07:10 AM
Colon Terminus
Sep 8, 2015 07:23 PM
