brain trust needed
Old May 1, 2009 | 02:53 AM
luis_o_98's Avatar
brain trust needed
ok i got a good one for you guys. i got a bolt down in the fuel tank how do we get it out with out taking out the fuek tank.
friend was installing a cb fuel door and dropped a bolt down my gas tube
Old May 1, 2009 | 03:10 AM
Jon316G's Avatar
Grasshopper
You might be able to reach it with the fuel pump removed
Never had my pump out before, so I don't know what the fuel tank cavity looks like.
Old May 1, 2009 | 03:12 AM
Spinning Sushi's Avatar
I <3 Sushi
Mazda has a special tool for the fuel pump. The fuel pump is going to be the only way to get into the fuel tank, remember to ground yourself or you might go kaboom.
Old May 1, 2009 | 03:15 AM
I <3 Sushi
You can also use the StealthTL method to remove the fuel pump.
Here's a guide to help you remove the pump to get to the bolt that's in your tank:
https://www.rx8club.com/series-i-do-yourself-forum-73/diy-clean-tank-sock-filter-164287/
Old May 1, 2009 | 10:08 AM
If you have driven the car its too late. Otherwise they have flexible metal tube with a magnet on the end of it.
You could have used that to go down and fetch it.
I wouldn't worry about the bolt.
Old May 1, 2009 | 10:30 AM
It isn't going to hurt anything...it won't plug up the fuel intake or anything.
If you are replacing your fuel pump or have it out...have a look around for it...otherwise I wouldn't worry about it
Old May 1, 2009 | 10:36 AM
luis_o_98's Avatar
well we thought of the flex magnet but didnt have one with us and it was about 2 am. also i dont think the bolt will do anything bad unless the rust gets in there but i think it will be fine thanks for the help
escapedan
RX-8 Racing
58
Feb 10, 2020 06:11 PM
GracefulShanks
Aug 18, 2015 11:40 AM
TheRedRotor
Aug 9, 2015 11:23 PM
SayDfuse
Aug 3, 2015 10:41 PM
