I think the Dealer screwed up my headlights, little help please
Old Apr 21, 2009 | 12:01 AM
cody6766's Avatar
I had my front bumper and driver's headlight replaced. I went out today to try and raise the cut off and realized it's not at all straight. The cut off is a broad U shape, putting the majority of the light high and to the sides. There's also a round shadow on the ground in front of the car that looks like the business end of a bullet.
The passenger side beam is wide and flat without the shadow.
Is this an installation issue or is the driver's side designed differently? If it is wrong, how can I fix it?
Old Apr 22, 2009 | 09:09 PM
cody6766's Avatar
ttt, anyone?
Old Apr 22, 2009 | 10:14 PM
lopezian2004's Avatar
Master Shr3dd3r
Sounds like they did. Get them to fix it, otherwise just get behind the front wheel wells to your headlight harnesses and re-insert your bulbs.
Old Apr 23, 2009 | 09:46 AM
cody6766's Avatar
is it just a matter of pulling the wheel and splash guard and then installing the bulb like a normal halogen bulb? I've never dealt with HIDs, so I'm not sure if there's anything new to know.
thanks for the help.
Old Apr 23, 2009 | 04:19 PM
Master Shr3dd3r
If I remember correctly it's the same thing as dealing with the halogen bulb, the HID bulb is just a little bit longer. Just make sure you don't touch the bulbs themselves!! There's a DIY around here somewhere I just don't remember which DIY it was... sorry!
Old Apr 23, 2009 | 11:24 PM
karstman7's Avatar
sounds like the bulb is incorrectly installed/ not the headlight itself...the bulb is easy to take out and put back in - a circular cover screws off and then a spring loaded finger clamp holds in the bulb....same happened to me
Old Apr 24, 2009 | 12:54 AM
cody6766's Avatar
right on, thanks for the help!
cliffkemp
Dec 24, 2024 10:48 AM
Shankapotamus3
Mar 14, 2021 03:53 PM
FubarI33t
Sep 28, 2015 08:45 PM
drlubell
Sep 26, 2015 11:58 PM
