Fender Grill Lights DIY
Old Apr 17, 2009 | 11:09 AM
candersonusa's Avatar
I just Finished installing some LED Lights behind my fender Grills. They look great.
And that is while there is alot of light, in the dark it looks wicked.
I used these flexible LED light strips from http://www.oznium.com/led-flex-strips.
1) Take the wheels off, and put the car up on Jack Stands.
2) Remove the Plastic Wheel Well Liners completley.
3)This is the Space where the Lights will go.
4) I ran the wires through the fire wall here. It is where your hood release cable goes through.
This is where it comes through on the inside, by your pedels.
5) I mounted the Lights to these right angle pieces of stiff plastic, and then covered them with aluminum Foil.
6) I then epoxied the lights into the channel.
7) I then mounted the Apparatus, with the wire going upward, directly behind the grill. First with zip ties, by drilling holes in the pieces of plastic, and linking them through the clips on my strakes. I then covered the entire back with duct-tape.
8) I then ran the wires from both sides into the engine bay, Soldered them together, and covered it with split tubing.
9) I then ran the wires in throught the firewall. And ran them up the side pillar to the Roof.
10) I removed the map light aparatus using this DIY.
https://www.rx8club.com/showthread.php?t=97596.html
11) Ground your wires here.
12) Draw Positive power from the blue wire on the little conncetor.
13) Set up your switch where ever you want, i chose underneath the sun visor
Old Apr 17, 2009 | 12:11 PM
04blue8's Avatar
zoom zoom
nioooce! i like it alot. good write up. i wonder how wb would look with blue lights??
Old Apr 17, 2009 | 12:48 PM
Texak's Avatar
Don't Tase Me Bro!
well done!! I'll try something similar. I like your 'reflector' idea. it spreads the light much more evenly than others I've seen.
Just bought 2 9.5'' blues. I'm going to splice power into my blue RR footwell lights so they come on automatically!
Old Apr 17, 2009 | 02:35 PM
ya, i used the 19" strips for mine.
Old Apr 17, 2009 | 04:20 PM
416to212's Avatar
Utopia Taco Bell
Nice idea and the end result is really good looking.
I have two little lights that I'm figuring out what to do with....
Old Apr 17, 2009 | 05:45 PM
kersh4w's Avatar
Hit & Run Magnet
the other car in the garage is quite nice too.
Old Apr 17, 2009 | 05:58 PM
Blue_Chameleon's Avatar
Wow....that is pretty impressive!! I like it.
Old Apr 17, 2009 | 06:29 PM
Alexb's Avatar
desperately needs a drop
You are the first person to solve the angle issue it seems.
Could you by chance take some outside night pictures at different angles? like one at standing height, one crouching, in front, from behind (thats what she said).
lonewolf did this but you could only see them at a low height. With your reflector idea, I think it will work.
Lastly, do you get a lot of glare or anything in sunlight from that light hitting the foil?
Old Apr 17, 2009 | 07:38 PM
Texak's Avatar
Don't Tase Me Bro!
Hey mods, can you move this to the DIY section? This is going to be a hit!
Old Apr 17, 2009 | 07:59 PM
Ya, I like the other car in the garage too, though I have never driven it. I havent havent noticed any glare from the sun, and I will get some pics from other angles and heights.
Old Apr 17, 2009 | 08:41 PM
YeahYeahYouWere's Avatar
Call me ROTO BAGGINS
This is one of the coolest mods I've seen on the RX8 so far. It makes me wish I had the mechanical proficiency and equipment to do such a thing. Can you imagine how jawesome it'd be to have blue LEDs glowing from the strakes of my Winning Blue GT?
Old Apr 17, 2009 | 09:00 PM
mscamp02's Avatar
Blue Bullet?
Thats something I would like to see as well
Great job BTW
Old Apr 17, 2009 | 09:53 PM
J8635621's Avatar
Pew Pew Pew
I like it! I want to see some night pictures though.
Old Apr 17, 2009 | 11:06 PM
myriadshalaks's Avatar
rot8ing
cool.
more pics, please. can you see the foil through the holes in the daytime?
Old Apr 17, 2009 | 11:29 PM
Texak's Avatar
Don't Tase Me Bro!
I was discussing with someone the possibility of wiring this (and footwells) up to the rear dome light. That way, we could have a toggle for it to either work for when the doors are opened, or are constantly on. Anyone see a potential problem?
Old Apr 17, 2009 | 11:58 PM
Alexb's Avatar
Instead wire them to an always on source, or to your headlights. The problem with the dome light, it always on. If you want the fender lights and the footwells on, you'll have to have the dome on....
I wired mine to headlights, and put a switch between them. So the switch has to be flipped AND the headlights have to be on.
I was going to have a switch to make it always on, or on with the door lights. But I couldn't find the door light wire, and spent a long time on my back and was in such pain I gave up.
Old Apr 18, 2009 | 12:30 AM
Alexb's Avatar
Well, that's kinda my point. I have blue LEDs in the dome, and i don't want to be cruising around all the time with the vent lights on. It will attract way too much attention. The toggle would have either everything on or off while driving, and everything turn on when you hit unlock on the key fob.
Well, in that case, I don't see a problem, except you might be overloading that power line if you're running 2 sets of extra lights (esp a LED strip). Not sure, but seems like it might.
Old Apr 18, 2009 | 12:33 AM
Texak's Avatar
Don't Tase Me Bro!
Well, that's kinda my point. I have blue LEDs in the dome, and i don't want to be cruising around all the time with the vent lights on. It will attract way too much attention. The toggle would have either everything on or off while driving, and everything turn on when you hit unlock on the key fob or open the door.
Old Apr 18, 2009 | 07:11 AM
From the outside the aluminum foil can not be seen. Even when you get down on ur hands and knees and look, it is just too dark in there. And i wouldnt wire them to the dome light. That means that you will have to have it on when the dome is on, i would wire it to an interior light that comes on with your headlights, and then a put a switch which breaks the circut. BTW what do u guys think of my switch.
Old Apr 18, 2009 | 07:39 AM
rot8ing
^very clean install.
Old Apr 18, 2009 | 07:42 AM
Mazurfer's Avatar
Surf Hard, Drive Hard
Possibly too much at night? Too many LEDs on the strips? Let's see some night pics.
Good job though!
Old Apr 18, 2009 | 10:39 AM
How would it work if you spliced them onto the turn signals? That might be kind of cool, to have the fender grill light up with your blinker.
Old Apr 18, 2009 | 11:31 AM
Alexb's Avatar
I did this for my footwell lights. This is the best way to do it for anyone wondering
I have not done this, but I think it would be a cool solution. However, Most states require white or amber turn signals, and I think the sides must be amber? So I'd beware of doing this
Old Apr 18, 2009 | 12:30 PM
You could always use a strip of amber LEDs to make it a turn signal. I don't know the legality of it, but I would think you'd be a lot less likely to get in trouble for amber LEDs I would think. Realistically, I think it'd almost make the vehicle safer by making your blinkers more visible.
Old Apr 18, 2009 | 01:06 PM
Alexb's Avatar
I've actually wanted to do this mod for a long time. I can't decide what'd be cooler. The blinker mod, or an always on (with the headlights) white LED. I have white LED clear corners and white parking lights, and 8000K headlights. Both would be pretty cool....
