DIY: The CORRECT way to remove the maplight / sunroof switch unit
Old Aug 28, 2006 | 10:07 AM
1145climber's Avatar
RX-8 Enthusiast
Thumbs up DIY: The CORRECT way to remove the maplight / sunroof switch unit
Here's a how-to on removing the map light / sunroof switch / sunglasses holder unit CORRECTLY. In all the DIYs I've seen, people just pry and yank it out by the front. Doing this could damage your trim, the unit itself, or more importantly, the metal clips holding the unit up that everyone seems to ignore. Follow these directions for a way to remove the unit properly without damage to anything.
Also, if using a screwdriver, it's a good idea to wrap it in electrical or some other sort of tape to prevent any possible damage to your trim. I personally never wrapped mine and never had a problem but don't be a fool - wrap your tool.
  1. Open the sunglasses holder and remove the two cross-head screws (image credit goes to Attack)
  2. Insert a flat head screw driver between the trim and the unit at a horizontal angle at once of the two boxed locations in the picture below.
  3. Carefully drop the handle of the screwdriver until it is basically vertical. This will pry the trim to the side a little, but dont worry about it.
  4. Push up on the screwdriver until the tip makes contact with the metal clip. Then, pry the clip in towards the center of the car. While you pry the clip away from the trim, make sure to exert a constant force towards to clip with the head of the screwdriver so that it doesnt pop off the clip. If at any point you feel the screwdriver pop off and you hear a metal "boing" then you know you're doing the right thing. Try again and apply more pressure to keep the screwdriver on the clip. Once you've pried the clip away from the trim, push up on the maplight unit to release it from the trim just in case it got caught, and then pull down to remove the unit. The picture below shows the clip and how the screwdriver is prying it away.
  5. Repeat on the other side. Once both clips are undone, just pull down the maplight unit and it should come out easily. Here's another picture of the metal clip with the screwdriver where it would be as you start to pry it away.
  6. The removed map light / glasses holder / sunroof switch unit. If you're looking to replace the maplights, just twist and pull the little black pieces circled in red. You may disconnect the electrical connectors if you want.
Well, hopefully that wasn't too complicated. Once you get the hang of it, youll be able to pry both clips out in under 10 seconds without much effort. Good luck and have fun!
Attached Thumbnails DIY: The CORRECT way to remove the maplight / sunroof switch unit-remove-overhead-light-1.gif   DIY: The CORRECT way to remove the maplight / sunroof switch unit-img_1230.jpg   DIY: The CORRECT way to remove the maplight / sunroof switch unit-img_1236.jpg   DIY: The CORRECT way to remove the maplight / sunroof switch unit-img_1237.jpg   DIY: The CORRECT way to remove the maplight / sunroof switch unit-img_1241.jpg
Old Aug 28, 2006 | 10:09 AM
RX-8 Enthusiast
Dont mind me, just needed a few more attachments for the DIY
Attached Thumbnails DIY: The CORRECT way to remove the maplight / sunroof switch unit-img_1234.jpg   DIY: The CORRECT way to remove the maplight / sunroof switch unit-img_1243.jpg
Old Oct 8, 2006 | 12:24 AM
TomAssBender's Avatar
Skeet skeet skeet
great DIY with awesome pictures. was worried about this after all the comments i read, but following these instructions was a piece of cake. of course, my T13 bulbs didnt fit! so i'll have to do it again
Old Aug 17, 2007 | 10:49 PM
TheBoneFletcher's Avatar
06 AT Winning blue! :D
Great guide! Just followed and it was perfect.
Old Aug 18, 2007 | 09:23 AM
Mazurfer's Avatar
Surf Hard, Drive Hard
One small issue with your DIY................I will admit I didn't read it as I already knew how to do all this, but if you didn't say so................make sure you wrap that screw driver with some cloth or tape or you will have the possibility of jacking up your headliner.
Old Aug 18, 2007 | 03:19 PM
RX-8 Enthusiast
ahhaha good point, i added that
Old Oct 28, 2007 | 02:31 AM
J8635621's Avatar
Pew Pew Pew
This DIY cleared up all my confusion on how to remove the maplight. The tiny picture in the owner's manual doesn't do the clips enough justice IMO. I had no clue they were so far up. Super easy with some real pictures.
Old Jan 16, 2008 | 07:54 PM
ModestoRX8's Avatar
Wish I would have found this DIY before I learned how to do it the hard way with lots of swearing aqnd eventually finding where the clips were.
Great Job!
Old Jan 16, 2008 | 08:04 PM
Mazurfer's Avatar
Great Job!
Yeah...........they are fun when you don't know........aren't they!
Hope you got to them and got it out without screwing up the headliner?
Old Jan 17, 2008 | 09:36 PM
ModestoRX8's Avatar
I did. It was not so much the headliner as it was the loud *PING* as I popped the first one out accidentally WAY too hard. I thought I broke it for sure. It was fine. Boo to having to remove the freakin' ceiling to change the map lights. .
Old Jun 15, 2008 | 08:35 PM
milo8460's Avatar
thanks this was a great help
Old Aug 18, 2008 | 08:49 PM
djcharlee's Avatar
Wow thanks for this, Helped allot.
Old Sep 10, 2008 | 06:28 AM
kainis2k's Avatar
saved me soo much trouble... thanks for the post!!!
Old Aug 25, 2009 | 10:24 PM
rubberduckie's Avatar
Great DIY. The instruction manual is good enough for the other interior lights, but I would have never figured this out without this thread.
Old Feb 16, 2010 | 04:12 AM
essmac13's Avatar
White Power
thanks
Old Feb 16, 2010 | 11:11 AM
Lunacy's Avatar
Registered Abuser
The 8's manual has this in it...
Old Oct 24, 2010 | 04:56 PM
RENESIS rotary's Avatar
what is the maps light buld sizes?
Old Oct 25, 2010 | 11:21 AM
Mazurfer's Avatar
Simple search would have brought up.
https://www.rx8club.com/showthread.p...ight=bulb+list
I'm not going to tell you what it is, so you will have to go and look and then have the list for the future.
This info can also be found in the manual for your car.
Old May 4, 2011 | 07:30 PM
phsalex's Avatar
IMPORT
what about the rear dome light can anyone show my a DIY for it?
Old May 4, 2011 | 09:31 PM
Mazurfer's Avatar
Not much to that one at all.
There's a picture in the manual on page 8-37(the 05 manual anyway), and it shows that on one of the longer sides of the plastic lens in the middle, there is a small indentation that you should be able to spot. Wrap a small screwdriver in a towel or something and pry it on that side.
The side to pry is opposite the side where the switch is located.
This assumes you are after just the bulb, if you want the whole assembly out, then it will be sort of like the map lights and you will have to sort of find out where to pry to get to the so-called clips to release.
Old Jun 24, 2011 | 01:09 PM
TX
Originally Posted by TrevorLeeC
Whenever I go to remove the screws they are really tight and I can't remove them can some one help please?
Grow a pair?
Old Jun 24, 2011 | 02:44 PM
TrevorLeeC's Avatar
Originally Posted by 9krpmrx8
Grow a pair?
actually where mine hasn't been touched sense it was made it had to be taken off with an automatic screwdriver which I found out so don't be a dick next time...
Old Jun 24, 2011 | 03:00 PM
TX
I'll try.
Old Jun 24, 2011 | 04:36 PM
CrazyJek's Avatar
"I wanna go fast!"
arent those called "drills."
Old Jun 25, 2011 | 04:28 PM
TrevorLeeC's Avatar
nope look it up
