issues with stock clutch...(i need help...)
Old Apr 14, 2009 | 08:07 PM
MelloYello's Avatar
MelloYello
NC issues with stock clutch...(i need help...)
over the past few weeks or so my clutch has been squeaking everytime i pressed the pedal. i really havent paid too much attention to it because it comes and goes. it is not a loud or annoying squeak. this morning during some heavy rain and very humid conditions, it was squeaking more than usual. i was on my way back to my office from a meeting for work. i got on to the interstate and as i entered third gear, i noticed it was difficult to change gears. the clutch was getting really soft. too soft. i managed to make it into fifth and when i tried sixth, the clutch pedal stuck to the floor. i pulled up the pedal and figured, this isnt good. needless to say it took me forever to get to work because the car would not go in gear. i finally got it into second and left it. i drove six miles in second at 40mph. when i made it to my office, i noticed that when i started pressing the clutch pedal it would suck itself to the floor but it still had some pressure to depress it all the way down. then i looked down and my clutch pedal has shifted to the right almost touching my brake pedal. it is also at an angle. i have no fluid leaks what so ever. could the be that the linkage or quadrant has broken? or should i consider slave or master cylinder? or possibly a new clutch and flywheel? any help or comments would greatly be appreciated.
Old Apr 14, 2009 | 08:13 PM
G3tR3DDY2GR3DDY's Avatar
search a lil bit next time..
common problem, buy a new clutch pedal or send it to BHR for rewelding.
Old Apr 14, 2009 | 08:15 PM
Jon316G's Avatar
Grasshopper
https://www.rx8club.com/series-i-trouble-shooting-95/clutch-pedal-snap-off-8-year-warranty-recall-%7E%7E%7E-132912/
Old Apr 14, 2009 | 08:16 PM
Easy_E1's Avatar
^Yep.^
Stick your head under the dash and look at the bracket. It more than likely has cracks in it.
Old Apr 14, 2009 | 08:17 PM
MelloYello's Avatar
MelloYello
Thank you. I'll give that a try and by the way this computer sucks @ss. it took me forever to even post this plus my iphone sucks too. its about time to throw it from the balcony but i wanted to get some answers first. thanks again.
Old Apr 14, 2009 | 10:56 PM
Blazed's Avatar
My clutch pedal squeaks whenever i press on the pedal. Should i be worried? What should i do?
Old Apr 14, 2009 | 10:57 PM
dozer's Avatar
on his 3rd rx8
^mines been squeaking for like a year now, no problems,,,,i say you dont worry
Old Apr 14, 2009 | 11:00 PM
Jon316G's Avatar
Grasshopper
Take the time to verify for yourself that nothing is wrong instead of just "letting it go".
Refer to pics in the link I posted above and see what others have encountered and where the failure point is.
Then, look at your assembly and see if you can notice any indication of possible metal fatigue.
Press in the pedal while you're under there and see/hear where its coming from... could just be the spring that is squeaking.
Old Apr 15, 2009 | 02:49 AM
dsire4u's Avatar
SS RX8
go get it fixed before it snap in the middle of nowhere man.
or BEFORE that, SEARCH
Old Apr 15, 2009 | 03:12 PM
syntheticdarkness's Avatar
ThEy MaDe Me Do It
Here it is again. This will help until you figure out what else you want to do.
https://www.rx8club.com/forum/showthread.php?t=170387
Old Apr 18, 2009 | 09:26 AM
MelloYello's Avatar
MelloYello
NC
Good morning all, just wanted to say thanks to everyone who replied. it was, indeed, the clutch pedal bracket. it took me a couple hours to fix. the bracket was shrapnel. i made my own reinforcements for it and had to reinforce the bushings for the spring because they had broke and the spring was carving the metal around it. i put it all back together and my clutch pedal is just about as tight as it has ever been. no more squeaking or softness in the pedal. thanks for everyone's help.
Audio Concepts ATL
Sep 26, 2021 01:59 PM
ei8ht
Aug 21, 2017 09:08 AM
DJclever
Sep 6, 2015 10:51 PM
tgaffner
Aug 20, 2015 10:55 AM
Stubbs
Jul 28, 2015 09:23 PM
