lowered on pedders low springs
Old Apr 13, 2009 | 07:26 AM
Greggk's Avatar
my buddy and i did the pedders low springs on his 04 rx8 and cant seem to get the alignment quite good enough... any suggestions? he already chewed through one set of tires and had it aligned and got it to -2.0ish but it still isnt good enough according to the alignment shop
btw here are some pics of the car
Old Apr 13, 2009 | 07:34 AM
cjkim's Avatar
^noob
that drop looks really uneven.
are you saying the alignment shop can't get it back to specs or your friend wanted -2.0?
either way, just zero out toe
Old Apr 13, 2009 | 07:40 AM
Greggk's Avatar
the drop looks the same as the one on pedders website that they did.
his buddy in california did the alignment and said it should be less than -2.0 but couldnt get it to go any further....
Old Apr 13, 2009 | 07:42 AM
cjkim's Avatar
^noob
Get it done somewhere else
but -2 won't chew tires. toe will
and fronts look high. did you preload?
Old Apr 13, 2009 | 07:47 AM
Greggk's Avatar
no just installed according to instructions we were given by pedders
Old Apr 13, 2009 | 07:51 AM
cjkim's Avatar
^noob
do this:
twist steering wheel all the way to one side.
go to each side and the loosen upper control arm bolts that is visible.
twist steering wheel to the other side and repeat on the other upper control arm bolts.
jump up and down on the car, go run over some speed bumps, whatever.
tighten bolts.
fronts need to be preloaded. if you didn't do this or use a jack to lift the wheel hub before tightening the upper control arms, you'll need to do this
Old Apr 13, 2009 | 07:55 AM
Greggk's Avatar
what????? are you serious??? thats just a bit dangerous lol
Old Apr 13, 2009 | 07:58 AM
cjkim's Avatar
^noob
if you mean 100% safe by dangerous, then yes, it's dangerous
note, i said LOOSEN, not remove bolts. there's nothing dangerous here.
Old Apr 13, 2009 | 08:02 AM
Greggk's Avatar
ok i misread what you wrote.. as i was reading it, it popped in my head that you said remove.... my bad. that would lower the front end? even though those pics were taken after driving from texas to california and back to texas?
as far as the alignment you guys suggest taking it to another shop or???
Old Apr 13, 2009 | 08:09 AM
cjkim's Avatar
^noob
no guarantees, but it only takes like 5 minutes tops.
if your guy can't bring it to specs, i'd look somewhere else.. especially if he can only bring it up to -2.0 (which is quite a bit of negative camber)
Old Apr 13, 2009 | 08:18 AM
Greggk's Avatar
well the alignment was done when my buddy was in cali when he found out his tires were all jacked up, so he spent like $800.00 on 4 new Bridgestone Potenza RE050A Pole Positions
Old Apr 13, 2009 | 07:10 PM
05rex8's Avatar
sold the 8... :(
fix the sag in the lower front bumper...looks terrible
Old Apr 13, 2009 | 07:17 PM
VASasha's Avatar
That's not the only problem with that bumper - check out the misalignment of it around the headlight.
Old Apr 15, 2009 | 04:36 PM
Greggk's Avatar
sorry for the delay responding to this. trust me i already told him about it, and we gotta redo his mesh so im gonna try fixing the bumper for him then
Old Apr 15, 2009 | 06:23 PM
05rex8's Avatar
sold the 8... :(
here is a trick to fix the sag--
bend the mesh back and up in the area that sags--it will support it
there should have been another mounting point for the mesh so it wouldn't sag in the middle
Old Apr 15, 2009 | 08:05 PM
Greggk's Avatar
cool good info. as you can tell by the 300c in the background, which is mine, i really dont know much about the RX8, but from what i see here on this site, its a cool little car and a cool community! :D
RXFEVER
Sep 11, 2016 02:51 PM
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
Paul_Y
Sep 21, 2015 02:23 PM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
