Blowing Fan Fuse, Overheating
Old Apr 10, 2009 | 02:36 PM
manicdk's Avatar
My car is overheating due to the cooling fans blowing a fuse, any suggestions what I can do other than taking it in for service? It seems somewhat difficult to inspect them myself because of the air filter location. My RX-8 has been nothing but trouble since day 1.
Old Apr 10, 2009 | 03:56 PM
Socket7's Avatar
ಠ_ಠ
It's not uncommon when changing the air filter, to push the grommets for the airbox down through the holes in the airbox tray, where they fall into the cooling fans and jam them. You can take the air box out, and the tray under it, then look at the fans and make sure they are spinning freely. If there is nothing obstructing them, chances are the motor on the fan is just burnt out and shorting.
Old Apr 10, 2009 | 03:58 PM
Atilla's Avatar
I am THAT guy
hmmmmm. interesting...
sounds like i might have the same issue.
Old Apr 10, 2009 | 04:04 PM
StealthTL's Avatar
Metatron
First observed in November, 2004.....
https://www.rx8club.com/series-i-trouble-shooting-95/gentlemen-check-your-grommets-45395/
The grommets have been redesigned.....
S
Old Apr 10, 2009 | 04:10 PM
Socket7's Avatar
ಠ_ಠ
Happened on my 07, but I didn't jam the fans thank god. I ended up taking the grommets that hold the engine cover in place and putting them down there. They're much stiffer and don't fall through.
Old Apr 12, 2009 | 01:07 PM
manicdk's Avatar
I willing to bet that is exactly what happened. For the time being I will just remove the relay for fan 2 (the one with a bad motor) and hopefully running 1 fan will keep the radiator cool enough. 100 bucks just for a fan motor is too much for such a stupid problem.
cliffkemp
Dec 24, 2024 10:48 AM
Shankapotamus3
Mar 14, 2021 03:53 PM
urbanvoodoo
Sep 30, 2015 12:41 AM
tommy26Germany
Sep 29, 2015 10:33 AM
pjwermuth
Sep 28, 2015 11:36 PM
