Tire Tread?
Old Mar 24, 2009 | 06:56 AM
k2www14's Avatar
Tire Tread?
how much rubber is there underneath the tread, my rear tires are bald in the center 1/32" left in the tread how many miles can i drive them before it blows or will what would happen. i currently dont have the funds for some new tires.
Old Mar 24, 2009 | 07:06 AM
Ryoma-kun's Avatar
Driving normally, it'll last for a good period but amount of grip is limited. I would be _very_ careful driving during wet conditions.
Old Mar 24, 2009 | 07:19 AM
Huey52's Avatar
Registered Zoom Zoomer
"Slicks" are great for the track, but as cited dangerous in the rain. If you're down to the wear bars you've got some wear left, as they're conservatively constructed for those who don't regularly check their tires. Obviously a priority for near future funds tho'.
btw: if your tires are bald in the center but you still have 1/32 tread on the outer rings you've been overinflating your tires just a bit.
Old Mar 24, 2009 | 04:22 PM
987HYS's Avatar
Dragon Certified
when you start to see the cord showing through the rubber is when you should feel really nervous. until then you just need to be very careful especially in wet conditions.
Old Mar 25, 2009 | 08:21 AM
k2www14's Avatar
huey thanks for the tire pressure tip ive been trying to learn that type of stuff as far as temp and all that where to be in the range that the manufacturer recomends and all that much appreciated to all
Old Mar 25, 2009 | 08:51 AM
Huey52's Avatar
You get a bit better gas mileage with a reasonably higher tire pressure, but again at the potential expense of rubber wear. Life is full of trade offs.
Old Mar 25, 2009 | 04:22 PM
NotAPreppie's Avatar
What am I doing here?
You'll start seeing the nylon cord before it becomes dangerous in dry conditions.
I'd consider you unsafe if the weather forecast predicts a 30% chance of rain.
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
Rx8 VA Guy
Jun 4, 2016 12:42 AM
snowrydr01
Nov 23, 2015 09:40 AM
Michael Bryant
Oct 12, 2015 03:07 PM
duworm
Oct 1, 2015 04:57 PM
