fd3s777
03-21-2009, 07:19 AM
Anyone had this problem? I have a 4AT. Under low speed sometime when the car try to shift gear from one to another the tranny locks up and car can only roll at 1-3 MPH and if too fast it lock up again. Its very dangerous cuz car behind me could of ran right into me. When this happen the AT warning light and skid warning light comes up. If I shift to manual shift numbers gear don't light up. I'm getting CEL code:
P0748 Pressure control solenoid
P0758 Shift solenoid B
P0846 Transmisson Fluid Pressure Sensor/ Switch
I check the service manual Pressure control solenoid and shift solenoid B they are under the tranny fix plate.
I want to make sure before I change these solenoids. Anyone ever had this problem? Will change ATF fix the problem? I did try reset the PCM. It helped. But after I shut off the car and ran it again, it did the same. ANy suggestion would be greatly appreciated. :)
