DOMINION
03-11-2009, 11:40 PM
:squint: dang it :banghead:
View Full Version : If your battery dies, can you pop the clutch on the 8? DOMINION 03-11-2009, 11:40 PM :squint: dang it :banghead: alnielsen 03-11-2009, 11:42 PM Yep, done it. AJ's Shinka 03-12-2009, 04:29 AM It was actually for me I was left stranded in the middle of the Nevada desert with a dead battery and I had to call the Dominion for help. Flashwing 03-12-2009, 05:34 AM Push start FTW!! DOMINION 03-12-2009, 06:28 AM ^LOL thats what I said. But turns out his battery died and his car got flooded when he tryed to start it. We tryed to jump it but she would not have it. After we put the new battery in, we had to use the washer fluid line to deflood his 8 then crank it stop, crank it stop, crank it stop. I think on the 4th try she turned over with a big ass back fire. Let her idle for a bit till the idle was smooth. Then he was good to go. I would like to give a big shot out to devoid! you da man. AJ's Shinka 03-12-2009, 01:03 PM Push start FTW!! Thanks but Dom helped me out. I need you on speed dial I would've called Phil but he is always sleeping for some reason. zoom44 03-12-2009, 03:13 PM i did mine in reverse i parking lot Silver06 03-12-2009, 03:18 PM As long as the battery has some voltage to power the ECU, coils (and security system), the car will start. I think the magic number is 9 volts.... DOMINION 03-14-2009, 11:07 PM ^This one was like beating a dead horse lol PRX8 03-15-2009, 11:42 AM Just buy either a Red or Yellow Top Gel Battery or even AC Adelco with 1000 cca dannobre 03-15-2009, 01:34 PM It's much easier to throw in the tow hooks in both cars...and pull it for a couple hundred yards. That way the battery can be stone dead...and the alternator will still give you enough current to get it going..and even if it's flooded it will start Hell...I started a couple of cars with one rotor and drove them like that after they were running.... |
