tranny doesnt like my new motor?
Old Mar 8, 2009 | 01:56 PM
JGR4444's Avatar
GR
I did a motor swap about 6 months ago and the motor came with a flywheel so i did not have to re use the one from my other motor and it seems like ever since then my tranny is a lot worse....
i never had issues before but now if i downshift into second a certain way or if i shift into 4th and 5th in a high rpm shift it grinds real bad... i know it sounds like synros but why would the new motor have an effect on this?
Old Mar 8, 2009 | 06:23 PM
Check the clutch slave..and make sure you re-bleed the clutch..
Clutch bracket is also suspect
Old Mar 9, 2009 | 12:15 AM
ppf alignment..
over..
theblinkof
Oct 4, 2023 05:24 PM
bosstin87
Oct 5, 2015 06:52 AM
Luke.s
Sep 30, 2015 05:57 PM
XianUnix
Sep 29, 2015 03:48 PM
