Horn stopped working?
Old Mar 5, 2009 | 04:08 PM
Shaftski's Avatar
Well, bound to happen eventually, I've hit the first problem w/ my Shinka. Went to hit the horn at some idiot who cut me off @ lunch today, and horn did not work. Pulled into lot at work, hit spot on steering wheel a bunch of times, and nothing, no horn sound. Worked fine when I first got the car about a month ago.
At first I though, fuse. But the horn does sound when I do the lock/unlock thing w/ my keyless remote, so the horn is getting power and able to produce sound. Not seeing any other electrical problems either.
Anything obvious I should check before calling the dealer for an appt? My guess is a bad switch or something.
Old Mar 5, 2009 | 05:21 PM
zoom44's Avatar
dont f with it as you could have a bag go off in your face.
its either the switch in the steering wheel or something blocking the contact. does it feel like it depresses the correct amount?
Old Mar 5, 2009 | 05:54 PM
shaunv74's Avatar
Power!!
http://www.youtube.com/watch?v=6S98pKVQxlY
Old Mar 5, 2009 | 06:10 PM
Shaftski's Avatar
No way was I gonna mess w/ the wheel, last thing I need is an airbag popping on me.
It does feel like it's depressing the right amount, but I did notice one other electrical oddity on the drive home from work. The fogs won't turn on by themselves, the headlights have to be on in order for the fogs to light up. Thought I could use them by themselves before w/o the headlights on?
Figured I would wind up calling for an appt, but thought I'd check here first, see if it was a common problem or not. Thanks for the help.
Old Mar 6, 2009 | 11:57 AM
EDZRIDE's Avatar
2005 White GT
Check the horn relay.
That's normal; fogs are wired into low-beams.
Old Mar 6, 2009 | 12:03 PM
TheWulf's Avatar
My 8 looks like a Smurf
If you need new horns I have some for you cheap
Audio Concepts ATL
Sep 26, 2021 01:59 PM
drebbrnator
Dec 27, 2018 07:02 PM
Aston177
Sep 3, 2015 11:07 PM
SIllver
Aug 1, 2015 07:34 PM
