Problems with AEM intake
Old Mar 1, 2009 | 09:12 PM
TRU5hot's Avatar
Hey has anyone had any problems with there AEM intake. When I data logged mine the MAF readings came out all chopy as they were inclining. Like the voltage would raise like 20 then drop 10 the up 20 then drop 10 and so on. Any help. thanks!
Old Mar 1, 2009 | 09:33 PM
Did you make sure it isn't your MAF sensor itself?
Old Mar 3, 2009 | 10:38 AM
DarthRX8's Avatar
Force User
MAke sure the two screens inside the tube are fitted correctly. If they are not your MAF and AFRs will be off!
Oh, and don't ask me how I know this.....
Old Mar 3, 2009 | 02:30 PM
DarthRX8's Avatar
Force User
For the record I never yelled at you
Between you and Jeff (who answered my emails almost immediately), my issue was taken care of quickly.
Looking back at my install I was in a hurry to get my intake back on so that I could enjoy my new ignition. I never thought that those screens could be dislodged so easily.
Old Mar 3, 2009 | 02:53 PM
DarthRX8's Avatar
Force User
I was panicing left and right and had to leave work early so that I could fix my "grown-up kids" toy.
Thank God you and Jeff are great customer service reps!
You can both take Saturday and Sunday off!
Old Mar 4, 2009 | 08:40 PM
TRU5hot's Avatar
What two screens? The ones inside the piping
Old Mar 4, 2009 | 09:04 PM
romycha1's Avatar
Yes
Old Mar 4, 2009 | 09:10 PM
Easy_E1's Avatar
AZ
One screen will actually work. I have one screen now. (I don't think I need to say what happened to the other screen ). And it works fine. Just make sure you have it installed correctly. And close to the MAF
Old Mar 4, 2009 | 10:24 PM
Jon316G's Avatar
Grasshopper
Didn't someone test out with just one screen and there wasn't much to benefit?
I think the 2nd screen was nice just to better smooth out the air flow.
But like you said, move it close to the MAF and it should be fine.
Old Mar 4, 2009 | 10:27 PM
SiLVeRE8's Avatar
a.k.a. WhITeRE8
damn i think this is my problem with my rough idle... recently just installed the AEM intake and i am experiencing idle dipping at full stop. i should recheck the screens
Old Mar 4, 2009 | 10:30 PM
Jon316G's Avatar
Grasshopper
^That and clean the MAF
Old Mar 4, 2009 | 11:02 PM
romycha1's Avatar
How do you clean the MAF?
Old Mar 4, 2009 | 11:09 PM
Jon316G's Avatar
Grasshopper
Remove the MAF housing from the intake.
Use MAF or electrical contact cleaner (can buy both at the local Auto store) and give the MAF wires a generous spray.
Let air dry before reinstalling (doesn't take long to evaporate).
Remember, the MAF is NOT the brown teardrop looking wire... that is the IAT sensor.
Up inside the housing you'll see two resistor wires, THAT is the MAF sensor
Old Apr 14, 2009 | 05:59 PM
TRU5hot's Avatar
Okay I know its really late but wow what a difference when I took off the screens. Is it okay that I removed both of them?
Old Apr 14, 2009 | 06:04 PM
No it is not.
Old Apr 15, 2009 | 08:34 PM
TRU5hot's Avatar
Why is it not okay
Old Apr 15, 2009 | 08:43 PM
Jon316G's Avatar
Grasshopper
The screens are used to smooth the air flow and reduce turbulence across the MAF sensor
Old Apr 15, 2009 | 08:47 PM
TRU5hot's Avatar
But its causing the readings to chop
Old Apr 15, 2009 | 08:48 PM
Jon316G's Avatar
Grasshopper
Are the screens damaged?
Old Apr 15, 2009 | 08:52 PM
TRU5hot's Avatar
nope
Old Apr 15, 2009 | 08:53 PM
TRU5hot's Avatar
So is it really THAT bad to leave them off or should I try and make one screen work
Old Apr 15, 2009 | 08:54 PM
Jon316G's Avatar
Grasshopper
I'm curious, the AEM screens are integrated into the couplings.
How did you remove them?
Or are you just drawing in unfiltered air?
Old Apr 15, 2009 | 09:09 PM
TRU5hot's Avatar
No there is a filter on the tip at the very bottom but when the pipe breaks down into smaller peaces closer to the engine the screens sit in between two of the pipes. They come out easily.
Old Apr 15, 2009 | 09:14 PM
Jon316G's Avatar
Grasshopper
I had the AEM for 2 years and never knew those screens just came out.
And just to verify the basics, you have the two couplers with screens just before the MAF housing and the reducer hump coupling at the very front?
Have you also tried cleaning the MAF with contact cleaner?
Old Apr 15, 2009 | 09:21 PM
TRU5hot's Avatar
Ill need to clean it to make sure that's not it. But having no screens is that much of a big deal
