Squeaky clutch pedal
Old Feb 15, 2009 | 07:23 PM
KrylonFuzion's Avatar
Just say no to pistons
Exclamation Squeaky clutch pedal
what the heck... I don't drive my car for a few days and the damn clutch pedal starts squeaking, i can feel it through my leg when i clutch... ugh . If someone could tell me how to get to it, or possibly why it is squeaking, I'd really appreciate it!
Old Feb 15, 2009 | 07:31 PM
robrecht's Avatar
TSB for Mazda to fix the clutch cut switch:
http://www.finishlineperformance.com...11-06-1724.pdf
Old Feb 15, 2009 | 07:33 PM
13bturbofc's Avatar
400whp RX-7+05 RX-8=BROKE
it is sqeaking right where the joint is above your foot. i took mine to the dealer for this problem and they greased it and i havent heard a sqeak yet..if you have warrenty take it in and make them do it. if you dont then get some lube and lube that joint up and press the pedal in and out till the squeak goes away.
Old Feb 16, 2009 | 12:14 AM
this is so peculiar- i have an 84 camaro thats beat to hell- never ever heard a peep out of the cluch pedal lol funny how that works- thanks!
Old Feb 16, 2009 | 12:53 AM
depending on year and mileage it might be a sign of the pedal getting ready to fail..
Old Feb 16, 2009 | 06:12 AM
Go48's Avatar
Crawl up under the dash and with a flashlight check the clutch pedal bracket bolted to the firewall for cracks. Fairly common problem that can cause squeeking.
Old Feb 16, 2009 | 08:51 AM
Jon316G's Avatar
Grasshopper
Like Go48 mentioned... check for cracks.
Commonly on the upper-left side of the pedal just above the mounting bolts.
Here is a pic of a local 8's pedal that was showing signs of metal fatigue:
Old Feb 16, 2009 | 04:43 PM
dsire4u's Avatar
SS RX8
You should Start searching
Old Feb 18, 2009 | 10:50 PM
you should try your hand at being actually being helpful, instead of PMSing
Old Mar 11, 2009 | 09:33 PM
Ceez76's Avatar
Ceez76
I have the same problem, do you know if the dealer covers the cost even if the car is no longer under warranty, i mean there is a tsb for it.
Old Jun 5, 2009 | 08:58 AM
jimdiddy21's Avatar
usually the clutch is the only thing not covered by the warranty due to wear and tear just like your tires. I'm actually going through the same bs im going ot mazda today. Im sure theyll say i need the whole cluthc replaced because they need the money so kinda fucked no matter what u know what i mean!
theblinkof
Oct 4, 2023 05:24 PM
mdl0209
May 23, 2019 05:46 PM
Eliseo Esquivel
Sep 30, 2015 08:28 PM
XianUnix
Sep 29, 2015 03:48 PM
tommy26Germany
Sep 29, 2015 10:33 AM
