Hard to put in Reverse
Old Feb 12, 2009 | 04:07 PM
bmcc81's Avatar
Hi,
I went up north last weekend and it was freezing rain. I left my car outside for 2 days and at the end of the weekend I went to start my car.
Well it started alright, but when I tried to put it in gear it wouldn't go...
I had to get home so I pushed it in pretty hard into gear.
The next day when I woke up I was able to shift into gear, but know I'm having problems with putting it in reverse.
Is there anyway to loosen up the gears OR WHAT SHOULD I DO
Thanks,
-bmcc
Old Feb 12, 2009 | 04:16 PM
what year is your car?
Stock shifter? Ever replaced the transmission fluids?
Are you pushing down on the shifter before trying to put it into Reverse?
Old Feb 12, 2009 | 04:17 PM
dozer's Avatar
on his 3rd rx8
^try that...if that doesnt work, you might need a new clutch...the short shifter HELPS a lot too
Old Feb 12, 2009 | 04:21 PM
the short shifter won't help his problem, especially if he bent a fork
Old Feb 12, 2009 | 04:23 PM
dozer's Avatar
on his 3rd rx8
^that guy LIES! he lies like a rug...dont listen to him he knows nothing and dont look at his post count
Old Feb 12, 2009 | 05:46 PM
bmcc81's Avatar
Thanks for the help
Hi,
Thanks for the quick response!
So, my car is 2004. I haven't replaced the transmission fluid ever, but I just bought the car last year. Does that matter. Also where do I look to check the fluid?
Also, what did you mean by "might have bent a fork"?
Old Feb 12, 2009 | 05:50 PM
How's your clutch?
Old Feb 12, 2009 | 05:58 PM
bmcc81's Avatar
Mu clutch seems fine. It pushes down easy, its just stiff moving the gears sometimes.
Old Feb 17, 2009 | 02:15 PM
bmcc81's Avatar
Question So I'm not sure
I'm bringing the car in tomorrow and I'm not sure what I should tell him to check. The clutch or the gears?
What should I tell them to check first?
This might save me some cash, so if anyone knows it would be appreciated.
Thanks,
Old Feb 17, 2009 | 02:26 PM
Huey52's Avatar
Registered Zoom Zoomer
We presume you know you need to push straight down on the stick before moving it to the reverse position. That innate difficulty is actually a safety feature so you don't inadvertently shift to reverse.
If it's really Very difficult I would first change the transmisison fluid. With gear wear over time (especially if the prior owner was a poor 'stickman' as it were) you build up metal shavings and if significant can make shifting difficult, especially reverse which again is inherently difficult.
Beyond that you may be looking at transmission work and/or shift fork. The fork is essentially two bladed and one side of it may be bent.
edit: from your description it sounds like the clutch is ok.
Old Sep 22, 2009 | 06:01 PM
Natesoucie's Avatar
im having the same problem. only the hard shifting has gotten significantly worse over the past week or so. i start the car in neutral,and try to shift into any gear whether first or reverse, it will not shift. when i final get it into gear, after loud grinding sounds. The car, with clutch still in still goes? any suggestions on what this mite be?
Old Sep 22, 2009 | 07:04 PM
^ That sounds like a clutch
Old Sep 23, 2009 | 10:09 AM
bmcc81's Avatar
I had the same problems when I replaced my clutch. It sounds exactly the same I'd look into that.
The reason why its sometime going into gear is because a tooth broke off the clutch and sometimes the clutch can fakll into position and other times no.
I'd go to a garage that you trust, don't bring it to Mazda too expensive.
- bmcc
GARCIAC951
Sep 10, 2015 07:17 PM
TJSiegrist
Sep 10, 2015 09:29 AM
mattymack
Sep 6, 2015 10:33 PM
superROB23
Sep 4, 2015 01:22 AM
nivong
Europe For Sale/Wanted
Sep 2, 2015 07:54 AM
