Clutch Pedal reinforcement welding question:
Old Feb 6, 2009 | 10:02 AM
Vyndictive's Avatar
"13B vs. Renesis" Discuss
Hey guys -
I know a couple vendors offer welded clutch pedals to prevent the brackets from separating due to the 2 small spot welds from the factory.
Anyway, I work in a weld shop and I'm going to weld mine in house (along with numerous clutch pedals from the others 8 owners in the area)
I've seen the TIG reinforcement weld that really lay it in there... but I feel that is a little bit of over-kill.
So, below is the picture where I'm planning to weld. 8-10 additional TIG welds around the outside of the bracket. (in yellow circles - the two red arrows mark the stock spot welds)
The 3rd pic is a repaired pedal, which I think is way too much weld for the stresses on the pedal.
I'm really just looking for any feedback or reasons why there should be more welding, or if anyone has broken their pedal, where did it fail and will these welds address that failure?
Thanks in advance.
Attached Thumbnails Clutch Pedal reinforcement welding question:-clutch-pedal2.jpg   Clutch Pedal reinforcement welding question:-clutch-pedal.jpg   Clutch Pedal reinforcement welding question:-clutch-fix-2.jpg
Old Feb 6, 2009 | 11:22 AM
I like the last picture.
Most brackets I've seen that were welded looked like crap.
too bad no one picks up from Mazsport.
They had a brand new brackect that was perfect.
Old Feb 6, 2009 | 11:51 AM
RK's Avatar
RK
It's Not Easy Being Green
Well I don't really spend a lot of time staring at my brackets so as long as the welds are functional.
More looking for feedback from anyone who's had a broken clutch bracket, anyone who has reinforced their clutch by welding, or anyone who has an aftermarket replacement clutch who thinks there could be more/less done to improve on Vyn's plan. Expect kudos all around but there's no reason not to throw this out there for commentary.
Old Feb 6, 2009 | 01:03 PM
Phil's 8's Avatar
FI by Pettit-BHR-Cobb AP
Originally Posted by Vyndictive
Hey guys -
Thanks in advance.
Obviouly you have not seen what gets returned as cores. I have seen them from a friend. Ears ripped off large holes were the stock attachments have flexed and ripped the metal out. I believe the extra weld is needed in all attached areas. I personally do not have a clutch pedal just commenting on what I have seen.
theblinkof
Oct 4, 2023 05:24 PM
projectr13b
RX-8 Racing
20
May 14, 2016 06:25 PM
duworm
Oct 1, 2015 04:57 PM
Eliseo Esquivel
Sep 30, 2015 08:28 PM
XianUnix
Sep 29, 2015 03:48 PM
