Skipping gears..
Old Feb 3, 2009 | 11:05 AM
GTConversion's Avatar
Clean and comfortable
Skipping gears..
Is there anything damaging / "incorrect" about skipping gears? A lot of times I'll get on the highway in 4th and get up to 75-85 and go straight to sixth. I wasn't sure if there was anything with the synchros, etc, that made this a bad idea. It just seems silly when I'm already at cruising speed on the highway to go into 5th and then immediately into 6th. Sometimes I also do this with 1st and 3rd, if I get up to 35-40 in first from a light, and it's a 35 mph zone.. I'll just go into 3rd.
Old Feb 3, 2009 | 11:09 AM
amstarvid's Avatar
ZM ZM X 8
I skip fifth all the time...
Old Feb 3, 2009 | 11:20 AM
Bastage's Avatar
DEVILMAN
Originally Posted by amstarvid
i skip fifth all the time...
^ +1
Old Feb 3, 2009 | 11:25 AM
Marklar's Avatar
As long as you aren't causing a big difference in RPMs between the engine and drivetrain or going into a gear that is too high for your speed, it's fine. For instance, if you're doing 60 in 2nd and want to go straight to 5th or 6th, that's OK. Skipping gears isn't a problem in itself, as long as you match revs or know you are already at the right speed for that gear you should be OK.
Old Feb 3, 2009 | 11:34 AM
gh8st's Avatar
STiMPACK
your biggest concern is rpm matching. skipping gear doesn't hurt anything.
Old Feb 3, 2009 | 11:36 AM
Socket7's Avatar
ಠ_ಠ
Skipping gears will extend the life of the syncros in the gears you do not use. Just rev match properly and no harm will be done.
I skip 5th all the time. I even do the odd 2-4 shift sometimes.
Old Feb 3, 2009 | 11:45 AM
zoom44's Avatar
5th to 3rd or even 6th to third is much fun
Old Feb 3, 2009 | 11:49 AM
TheWulf's Avatar
My 8 looks like a Smurf
Hell yes!
Like everyone else said.. rev match = no problem!
Marklar's Avatar
LOL, sometimes on the highway I drop from 6th to 3rd just for fun, not even to accelerate. I see the heads of other drivers near me turn around like "WTF?!" Once a guy tried to chase me when I did it, but I wasn't really wanting to take off.
Old Feb 3, 2009 | 12:15 PM
TheWulf's Avatar
I use 6th to 3rd all the time to pass... with the CAI+exhaust, I get a good sound out of it. Especially in tunnels
Old Feb 3, 2009 | 12:20 PM
Gauge's Avatar
Not Jeff Gordon
5th or 6th to 3rd is the greatest feeling I get out of my car lol
Old Feb 3, 2009 | 01:14 PM
I primarily meant shifting up.. I shouldn't have to rev match that, right? It's always going to be lower RPM. I do rev-match on the way down.
Old Feb 3, 2009 | 01:19 PM
Marklar's Avatar
Right, you generally don't need to double-clutch an upshift.
Old Feb 3, 2009 | 01:25 PM
TheWulf's Avatar
You won't have to give it gas, but you should still rev match (ex: don't force it in at 5500 rpm if it needs to be at 2500).
Old Feb 3, 2009 | 03:07 PM
AAChaoshand's Avatar
Rotary Powered
Indeed, double clutch when going down though say 6th to third at like 80
Old Feb 3, 2009 | 07:32 PM
Gauge's Avatar
Not Jeff Gordon
6th to 3rd at 80 ? lol
Where you drive the autobahn :P
Old Feb 3, 2009 | 08:40 PM
hakuna matata!
doing 60mph in 6th and dropping into 3rd + arming my nitrous = OMG!
Audio Concepts ATL
Sep 26, 2021 01:59 PM
reddozen
Series I Engine Tuning Forum
Aug 7, 2015 10:20 AM
dodo
RX-8 Racing
17
Nov 12, 2004 10:30 PM
JeRKy 8 Owner
Aug 5, 2004 01:27 PM
mamccubbin
9
Oct 2, 2003 11:53 PM
