Slightly rough idle
Old Jan 30, 2009 | 11:27 PM
mlfarrell's Avatar
Slightly rough idle
Do any of you guys ever have a few rpm dips (maybe from 800 into 700 range) and a slight shutter when it happens? It never stalls out or anything but I still don't like it - esp in this cold weather. especially with all this engine failure talk and stuff.
Old Jan 30, 2009 | 11:43 PM
Could be normal. Go to a local club meet.
I would clean the MAF.
Then if it is still there look for a vaccum leak.
The plugs foul over time because the car is too rich
Old Jan 31, 2009 | 12:29 AM
EdwardsB's Avatar
Registered RX-8 User
did you get the latest flash done yet? mine had the same problem, but after this it is rock solid.
https://www.rx8club.com/rx-8-discussion-3/newly-revised-rx-8-service-bulletins-140702/
Old Jan 31, 2009 | 12:43 AM
mlfarrell's Avatar
https://www.rx8club.com/showthread.php?t=140702
according to dealer, I got the latest engine flash
Its really not THAT bad. You know, its just not running"like new" either
I may see what mazda can do during my 30k mile service
Old Jan 31, 2009 | 01:05 AM
Brettus's Avatar
Boosted Kiwi
it is pretty common for that to happen .
Since a recent rebuild I notice my idle is way better than it used to be - vacuum is the same .
When the motor was apart i noticed carbon buildup at the trailing end of the exhaust ports actually partially blocking the port . That may have been responsible for the stuttering idle on the old engine , will never know for sure .
Old Jan 31, 2009 | 01:50 AM
hakuna matata!
I too have been having a rough idle recently.. I'm thinking my MAF is being fussy because I took apart my intake and found a load of oil in the accordion tube.
Old Jan 31, 2009 | 02:20 AM
DOMINION's Avatar
I don't buy Kool-Aid
My friend just took his car in for this. He said his RPM's would dip hard like the car was going to stall. Its bad coils new wires and might need new plugs too. Dont get stealer ship rapped buy the stuff and do it at home. Its a 1hr job tops.
Old Jan 31, 2009 | 08:35 AM
mryoshi's Avatar
Pyscho Dad
I had same issue.
Dealer replaced motormounts and coils under warrany. Purrs like a kitten now.
Old Jan 31, 2009 | 08:53 AM
Rhawb's Avatar
Has the whole shit.
My 8 used to hate idling. It would shudder and burble while dropping about 250 RPMs every minute or two. It didn't seem to cause any problems other than a vibrating seat and shifter, so I never worried about it too much.
Old Jan 31, 2009 | 09:41 AM
04RX8man's Avatar
Rotary Powered Countryboy
I get this every once in awhile at idle. However i am on the stock/original coils and plugs at 41k miles so taking care of those should take care of the problem
Old Feb 1, 2009 | 12:54 AM
https://www.rx8club.com/showpost.php...54&postcount=8
hey,
but what do i know..
but it could also be low compression. plugs, wires, coils, fuel pump. recently reset ecu..
Old Feb 1, 2009 | 01:02 AM
yokohamaboi's Avatar
Tea?
hey,
Low compression? is that a common thing?
Old Feb 1, 2009 | 01:07 AM
depends on lots of factors. but for the most part, not so much..
Old Feb 1, 2009 | 01:44 AM
hakuna matata!
Compression is a key indicator of engine health, especially in a rotary.
Old Feb 1, 2009 | 01:07 PM
Earl the Pearl's Avatar
Have to agree with the new plugs and coils. Mine would do this once and awhile and recently misfired causing the check engine light to come on. Dealer replaced all plugs and coils under warranty and it has been fine since.
cliffkemp
Dec 24, 2024 10:48 AM
Shankapotamus3
Mar 14, 2021 03:53 PM
Danield97
Sep 30, 2015 05:59 PM
Quiggs321
Sep 30, 2015 05:34 PM
