question about stock head unit + Kenwood CD Changer
Old Jan 28, 2009 | 10:05 AM
Imphaetus's Avatar
Did It Myself
I want to keep my stock head unit and i was just given a Kenwood 10Disc changer, would it be possible(w/o costing much) to hook the changer up to the stock unit? the stock unit does not have the 6disc changer. and how hard is it to hook up subs+amp to the stock head unit? i have the amp and sub, but i want to hook them up myself, i had best buy hook up subs in an old car of mine and they did a TERRIBLE job at it
Old Jan 28, 2009 | 10:29 AM
czar's Avatar
Almost boosted
the port on the back of the head unit is technicaly for a cd changer but never seen anyone use it for that, nor do i know what type of adapter would be needed to make it work with other cd changers
Old Jan 28, 2009 | 10:38 AM
Socket7's Avatar
ಠ_ಠ
In short? No. Aftermarket and OEM equipment will not talk to each other unless specifically engineered to do so. You could buy the OEM 6 disk changer and install it in your OEM head unit though.
Adding a sub isn't that bad, you can hook a line output converter to the rear deck speaker lines and drive the sub off them, but for your car's sake, take it to a qualified car audio shop. Best buy may train their employees how to connect the wires correctly (most of the time) but that doesn't mean they train their installers in how to properly tune and balance a system, or give them the time to do it.
Old Jan 28, 2009 | 07:57 PM
firebirdude's Avatar
User and Abuser
No way jose.
And $30 Line output converter after the Bose amp if you have it.
ei8ht
Aug 21, 2017 09:08 AM
Crazy.8
Apr 18, 2017 03:17 PM
arjunmshah
Aug 6, 2015 10:56 AM
MolecularConcept
Aug 1, 2015 03:15 PM
ion_four
Jul 30, 2015 09:48 PM
