transmission gear questions
Old Jan 27, 2009 | 09:01 PM
sauceyI986's Avatar
I was wondering if any one knows who can make any dog gear set for the rx8 transmission, like a replacment. Already have done searches couldn't find much. The gears are grinding bad from 1st 2nd and 3rd. I don't mind insting the gears my self I just need something ithat can last.
Old Jan 28, 2009 | 10:52 AM
olddragger's Avatar
do you have the short shifter and what kind of oil are you running?
The reason i ask is that I was ready to buy a new trans (4th gear grind) at 61K) BUT, i was still running the old yellow **** on the ss and i was running mobil 1 oil.
well i placed the oem shifter back in while i updated the ss to the new **** and i put regular gl3-gl4 coastal state cheap *** trans oil from advance auto into the trans with 5 ozs MMO (nothing to lose right?). Guess what---trans is as smooth as butter and no grinding at all---none.
olddragger
Old Jan 28, 2009 | 08:59 PM
sauceyI986's Avatar
Nope I don't have an ss line or a short shifter. Sometimes. I'm not able to even shift into 2nd unles I go around 12mph. So I'm like I don't know now just needs some **** that not hella I'm so tempted to get a rx7 transmission and and dog gears to it but I like to know is there any way to beef up the current rx8 transmission
Old Jan 28, 2009 | 09:23 PM
A "dog box" isn't going to shift as well as a stock tranny..they are straight cut gears....really strong...but they shift poorly without a lot of help
Try changing out your fluid....and see what happens......otherwise you can pick up a used tranny cheap if you are out of warranty
Old Jan 28, 2009 | 09:45 PM
sauceyI986's Avatar
Ok I hear u on that I did replace the fulid when I replaced my clutch but it tarted only grinding geras wehen I had my engine replaced by mazda now it just all bad.
Old Jan 28, 2009 | 10:09 PM
sauceyI986's Avatar
Old Jan 29, 2009 | 06:53 PM
Charles R. Hill's Avatar
Owner of BHR
How much free-play do you have at your pedal pad?
Old Jan 29, 2009 | 07:36 PM
04RX8man's Avatar
Rotary Powered Countryboy
I'm with the replacement of fluid!
Old Feb 1, 2009 | 01:41 PM
sauceyI986's Avatar
I don't really have much free play at all. Just gear proplems that's all
Old Feb 1, 2009 | 03:21 PM
olddragger's Avatar
clutch adjustment or maybe even ppf adjustment?
OD
Old Feb 4, 2009 | 03:07 PM
sauceyI986's Avatar
ok well does anyone know of a shop that can do custom dog gears in the rx8's transmission case
gwailo
May 14, 2024 06:57 AM
Dokuji
Nov 1, 2016 02:51 PM
DJclever
Sep 6, 2015 10:51 PM
