CO2 cool down air temps?
Old Jan 22, 2009 | 06:00 PM
nc.wiles's Avatar
Random question:
Who has any idea if CO2 would make an noticeable difference to air temps entering the motor?
Explanation to follow....
Old Jan 22, 2009 | 07:13 PM
tsxmidship's Avatar
sure, any heat exchange source with a lower temperature than the intake temperature would cause the intake temperature to drop. you have to define noticeable though.
Old Jan 22, 2009 | 07:21 PM
eviltwinkie's Avatar
Originally Posted by nc.wiles
Random question:
yep...it would prevent combustion...haa haa
Old Jan 22, 2009 | 07:28 PM
paulmasoner's Avatar
Asshole for hire
i assume you mean to fog an IC or something and not inject into the stream...
Old Jan 22, 2009 | 07:55 PM
04RX8man's Avatar
Rotary Powered Countryboy
yeah to "fog" an intercooler or use it to cool something yes it would cool down the temp but injecting it is not good.....at school we spray nitrous direct port and also spray nitrous on the intercooler for even higher numbers...(ford Lightning)
Old Jan 22, 2009 | 07:58 PM
Asshole for hire
yeah i was sure he meant that as well but just saying... think is it still doesnt make sense.... CO2 isnt the best thing to fog with
Old Jan 22, 2009 | 08:00 PM
04RX8man's Avatar
^yeah like I said we use Nitrous and get some good numbers but personally think it's a waste of money to just spray ON the IC but hey not my money for the Nitrous!
Old Jan 22, 2009 | 08:34 PM
nc.wiles's Avatar
I will be using Nitrous or CO2, havent decided yet. A little experiment I will be working on with a few car guys.
Old Jan 23, 2009 | 06:27 AM
sigh...
to solve your issue with your K&N...buy a better intake...you know...like the RB...
and your little experiment is only going to net you .5 HP with 10x the energy required to do it...
i'm just telling you right meow...
Old Jan 23, 2009 | 07:42 AM
DOMINION's Avatar
I don't buy Kool-Aid
Look into the zex one.
Old Jan 23, 2009 | 10:57 AM
04RX8man's Avatar
IDK we netted quite a bit of HP gain but we were also working with a S/C lightning so i'm not sure about this motor!
Old Jan 23, 2009 | 11:08 AM
NA vs FI is different...in FI applications it makes a difference...in NA, not so much...
Old Jan 23, 2009 | 11:12 AM
04RX8man's Avatar
^oh i know it does just saying that' i've seen it done to make more but having NA will not net much if anything....I wouldn't waste the money unless u were FI
Old Jan 23, 2009 | 11:24 AM
Asshole for hire
good catch on the sig info twinks, i didnt even lookat his sig... failure is immenant
Old Jan 23, 2009 | 05:18 PM
nc.wiles's Avatar
I will be FI, I am buying a ProCharger off a buddy this summer. Money isnt really an issue either, so dont worry about that. I just wanted an opinion, not a bunch of ******* feedbacks. Thanks.
Old Jan 23, 2009 | 05:20 PM
Asshole for hire
lol dont take it so personal... we did give you our opinion... you dont have to like it or even believe it
Old Jan 23, 2009 | 05:27 PM
StealthTL's Avatar
Metatron
Not so much.
Where I am, I can guarantee a steady intake temperature of minus 30*F, and it don't do squat for my power.
If you go FI, the cooler temp will be after the intercooler, and never seen by the ECU sensors, so the mixture and timing would already be set for the intake temp.
It would also be difficult to keep all the CO2 out of your intake air, due to the proximity of IC and CAI. Even a little (10%/vol) would negate any benefit.....
S
Old Jan 23, 2009 | 05:31 PM
Asshole for hire
S
thinking the same thing...
i didt think afr had anything to do with IAT? but yeah timing...
Old Jan 23, 2009 | 05:41 PM
Then you should restate your question to include all the proper information instead of ASSuming anything and creating such a general question that you'll get the wrong feedback...
Your question...fails...
Your attempted recovery also...fails...
Prochargers...without oil...fails...
Air with CO2...ignition...fails...
Old Jan 23, 2009 | 07:12 PM
Socket7's Avatar
ಠ_ಠ
Real men cool their intercoolers with liquid nitrogen.
Old Jan 23, 2009 | 07:18 PM
09Factor's Avatar
Original Turbo 'd Auto !!
^^^ True but i'm not in the mood to tote around a Dewar flask.
Old Jan 23, 2009 | 07:19 PM
Real men cool their intercooler with the cool of their manlyness...
Old Jan 23, 2009 | 07:26 PM
Socket7's Avatar
ಠ_ಠ
But you could route the vent to the wheel wells and have fog billowing out from behind the wheels at stop lights. That would be so cool it would have to at least 30-50 HP.
Twinkie, I tried that once and all I did was burn my yambag really badly.
Old Jan 23, 2009 | 07:28 PM
Asshole for hire
like this?
JimmyBlack
273
Feb 10, 2020 10:23 PM
RXFEVER
Aug 29, 2018 10:14 AM
RXFEVER
Sep 11, 2016 02:51 PM
Vedivan1
Sep 20, 2015 04:39 PM
Vedivan1
Sep 18, 2015 12:39 PM
