View Full Version : Sport Package Std on 6sp
fritts 01-07-2003, 04:26 PM I was wondering it seems like I have read this in reviews on the 8 that the sport suspension package,(18"Rims, Big Brakes,sport suspension) were going to be standard on the 6speed 8. If this is so, man, Mazda is creating a great deal at 26,600 or whatever it is.
Is this true that the sport package is std on the 6sp in the U.S.
Quick_lude 01-07-2003, 04:46 PM Hehe.. I was wondering the same thing.. I just asked about the 16" "base" wheels. If we get the 18"/suspension/brakes for 26600 that would be an amazing deal. :)
snow_tires 01-07-2003, 05:24 PM i just looked at the press kit,
(in north america)
the 6sp manual only comes with the sport suspension and 18 inch wheels.
BANG!
cueball 01-07-2003, 05:44 PM No big brakes?
Hercules 01-07-2003, 06:21 PM Originally posted by cueball1029
No big brakes? EDIT: There are 16" brakes on the standard model, 17" on the high power.
RedRotaryRocket 01-07-2003, 06:54 PM Hey Herc,
Where is this data from....not to be a party pooper, but I don't think it is accurate. How can they have 16" brakes on the non-sport model when the wheels are only 16"? Unless the RX-8 employs a really cool inboard brake design, this just isn't possible. Besides, 16" and 17" brakes are ridiculously huge. I would expect 13" max....though larger would be cool :D
Hercules 01-07-2003, 06:57 PM Originally posted by RedRotaryRocket
Hey Herc,
Where is this data from....not to be a party pooper, but I don't think it is accurate. How can they have 16" brakes on the non-sport model when the wheels are only 16"? Unless the RX-8 employs a really cool inboard brake design, this just isn't possible. Besides, 16" and 17" brakes are ridiculously huge. I would expect 13" max....though larger would be cool :D Mazda has put out a press kit chock full of information.
I've verified my findings in this thread with an attached image, so take a look for yourself :)
Here's the thread. (http://www.rx8forum.com/showthread.php?s=&threadid=1673)
RedRotaryRocket 01-07-2003, 07:01 PM Ah...there's the problem. 16" type and 17" type are refering to the wheel size, I believe. If you convert the mm to inches, you'll see that the disc diameter is 12.7.
RedRotaryRocket 01-07-2003, 07:03 PM Off topic, but does that nifty press kit happen to list the compression ratio?
Hercules 01-07-2003, 07:03 PM Originally posted by RedRotaryRocket
Ah...there's the problem. 16" type and 17" type are refering to the wheel size, I believe. If you convert the mm to inches, you'll see that the disc diameter is 12.7. Long day... you understand :)
I don't wake up at 7:30 in the morning during my winter break often :p
zoom44 01-07-2003, 07:05 PM 323mm is roughly 13 inches for the big wheels
303mm is roughly 12 inches for the little wheels
302mm or again roughly 12 for the back wheels either way
RedRotaryRocket 01-07-2003, 07:07 PM In any case, 12.7 is GREAT for a car that weighs ~2900 lbs. If my memory is correct, the brakes on the FD RX-7 were 11", and it weighed nearly the same.
B-Nez 01-08-2003, 12:04 AM Originally posted by RedRotaryRocket
10.0
From the Full Presskit PDF file, page 122 (as numbered on page). There is a complete chart of all the specs, but could not find it individually in the images area. Export is kinda small:
http://members.cox.net/tonecrusader/Spec_chart01.jpg http://members.cox.net/tonecrusader/Spec_chart02.jpg
Edit: Forgot the 3rd piece of the chart:
http://members.cox.net/tonecrusader/Spec_chart03.jpg
Quick_lude 01-08-2003, 12:08 AM Curious how they don't list curb weight.. :confused:
HEY! We lost 3 ft/lbs of torque! :p
eccles 01-08-2003, 12:16 AM I wonder why the Japanese 6-speed gets a slightly taller 3rd gear. There must be a good reason why they'd bother to cut a separate cog just for that one variant.
Anyone? Beuller?
Gord96BRG 01-08-2003, 01:51 AM Originally posted by RedRotaryRocket
That's accurate - it just isn't referring to the diameter of the brake disc. This form of reference to the size of the brakes is used in Europe and elsewhere, where they refer to the size of the wheel required to clear the brake disc and caliper. So, the "16" brakes" require a 16" diameter wheel at a minimum, and the "17" brakes" require a 17" diameter wheel at a minimum (note that the Sport suspension package uses 18" wheels anyway - so you should be able to get winter wheels and tires in a -1 sizing on 17" wheels!). The information also lists the exact brake disc diameter separately.
Regards,
Gordon
RX-3_13B_Tommo 01-08-2003, 05:26 AM Go to the mazda usa new RX-8 page. On it you can build your own, with the pagake and trim and the whole shit. It's awesome
