View Full Version : dentist drill sound?
HERO
01-18-2009, 07:19 PM
This started about a week ago. Upon the car's first startup of the day, There's this dentist's drill kind of sound coming from the engine. It goes away once the cars is warmed up, but it has never done this before but has everyday for roughly a week now.
any thoughts?
dannobre
01-18-2009, 07:26 PM
Secondary Air injection Pump.....
Thing is crapping out.......runs for a couple of minutes on cold start to warm up the CAT
HERO
01-18-2009, 07:31 PM
hmmm, is it a necessary fix (as in, is it harmful to leave alone?)? Is it an easy fix? I really have no clue where or what it is aside from what you just mentioned. I have no problem doing the work myself though.
am22
01-19-2009, 12:48 PM
Me too I got the same problem going on with my car, but I don’t know if I should replace the pump or not. Is it necessary?
rotary.enthusiast
01-19-2009, 12:56 PM
It's there to help the cat hit optimal temperature faster for emissions reasons. If it's not working you will produce more emissions each time you start the car, because the cat won't be working properly for a longer period of time. It's nothing to be overly alarmed about. If it fails totally you should get a CEL.
04RX8man
01-19-2009, 04:42 PM
yes it's not a must just helps...I believe alot of the FI guys disable this all together!
