magnaflow high flow cat
Old Dec 17, 2008 | 04:49 PM
schnipster's Avatar
what are the benifits
louder?
quieter?
gas mileage increase?
torque loss?
hp gain?
HELP
Old Dec 17, 2008 | 05:41 PM
heyarnold69's Avatar
Rotary wanabee
i have the rp high flow cat... nothing but good things. having a high flow cat will make it louder n raspier. is raspier a word? Magnaflow usually makes top quality stuff so probably same result
You will get a few extra hp
high flow cat + greddy sp2 = ~22 extra hp
Old Dec 17, 2008 | 05:46 PM
rx 8speciale's Avatar
Relax baby!
Louder ,thats It If You Get A Test Pipe And Probably With Catback You Will Free 10hp.... Maybe....
Old Dec 17, 2008 | 07:17 PM
schnipster's Avatar
are any of these hp numbers proven, and i was also told that these thing burn up fast? is that true?
Old Dec 17, 2008 | 08:42 PM
Jbill21's Avatar
Alright.. ive really learned a lot the year and 1/2 that I have owned the eight and been on this site...but one thing I have always been confused on is the difference between the high flow cats...mid pipe's test pipes and all those other pipes...Can someone help me out. Also, I know midpipes bring up the CEL but are there and high flows that don't?
Old Dec 17, 2008 | 10:46 PM
alnielsen's Avatar
louder?
quieter?
torque loss?
hp gain?
HELP
Is the magnaflow high flow cat a ceramic or metal cat? The ceramic core cats can't stand up to the exhaust temperatures produced by the rotary engine. And while metal cats can withstand greater temperatures, many of those fail also. Also, when your looking for a high flow cat, look for the number of "cells per inch" CPI. 150CPI is average, 100 CPI is better because it flows easer. Of the pre-made high flow cat mid pipes out there today, the RP Supercat is the most popular.
A high flow cat is just like the emissions system presently on your car. The only difference is this cat will pass the gasses through more easily. This allows your car to be emissions legal (in most locations) and you will still get a HP gain.
A mid-pipe/test pipe is a straight through pipe that replaces the one with the catalytic converter. It is loud and will smell due to the alcohol in the gas being burned. The cat normally gets hot enough to burn off what makes that smell. This pipe will result in the most HP gain.
Then there is the resonated mid-pipe. This is just like the mid-pipe/test pipe, except it has 1 or 2 resonators (mufflers) on the pipe to quiet the exhaust. This is desired by most people due to the noise a rotary engine makes. An unmuffled rotary is extremely loud and will cause hearing damage. The resonated mid-pipe will give you virtually the same HP as the straight mid-pipe and keep your relations with the neighbors & police on better terms.
Old Dec 17, 2008 | 10:53 PM
Jbill21's Avatar
Thanks for the info. I gained some knowledge about them over time by just reading other threads... Sorry but I have a few more... Does the high flow pull the CEL? Does it gain less HP than a straight mid pipe? Id like to get one sooner or later but didnt want to pull the CEL and have it smell real bad... Prolly go with the high flow unless there is something else
Old Aug 31, 2012 | 09:21 PM
iwearmykswiss816's Avatar
Originally Posted by sfsoldier14
I have actually been wondering the same about the CEL with a high flow cat. I live in NY so my cat delete pipe isn't going to fly when it comes inspection time. I have been looking at the universal fit Manga flow cat and i am wondering if anyone knows for sure if it will clear my CEL? Is it worth dropping the money on?
When i put the magnaflo cat on it cleared my cel after the second time i drove it
Old Sep 1, 2012 | 04:08 PM
xexok's Avatar
In NY do you have the sniffer test or just the obd2 test? I have heard that high flow cats will not pass a sniffer test but it might depend on the cat and the state.
Old Sep 1, 2012 | 09:09 PM
xexok's Avatar
If they go inside the car and hook up to the obd2 port then yes that is all. If they stick a hose on or near the exhaust then thats the sniffer test. In vegas it is just the obd2 test and pretty easy to defeat it even with no cat.
Old Sep 1, 2012 | 11:09 PM
GK1707's Avatar
Its just an OBD2 test done here in NY. No sniffer for emissions.
Old Sep 2, 2012 | 11:04 AM
awesome. Just the answer i was looking for. How long have you had it on for?
Ive had it on for about 5 months now
WranglerFan
Aug 21, 2022 01:29 PM
WranglerFan
May 31, 2022 07:51 AM
JimmyBlack
273
Feb 10, 2020 10:23 PM
WranglerFan
Nov 5, 2017 09:35 AM
Hiroshima_RX
Sep 21, 2015 06:28 PM
