Shifting problem
Old Dec 9, 2008 | 10:38 PM
katafuji's Avatar
Shifting problem
I just changed my trans oil with redline MT-90 and now I'm having problems downshifting to 3rd and 2nd. when i downshift to 3rd and/or 2nd, sometimes it shifts smoothly and sometimes it doesnt go into gear all the way like it gets blocked half way. I'm not really sure what the problem could be but I think it's either my synchros or the forks. pls help
Old Dec 9, 2008 | 11:32 PM
wheyluhai's Avatar
Newb in Training
what kind of gear oil were you using prior to MT90?
Old Dec 10, 2008 | 10:30 AM
I believe you should be using 75-90
Old Dec 29, 2008 | 09:44 PM
katafuji's Avatar
whatever oil the mazda dealer put in it.
Redline MT-90 is GL4 75W-90
Old Dec 29, 2008 | 10:02 PM
katafuji's Avatar
after about 5 min of driving when the car is cold, the transmission is like butter, but during those 5min I can't downshift into 3rd or 2nd. I know that your supposed to let the tranny warm up to get the smooth shifting, but the redline lube takes longer than the stock. I talked to a couple guys last night at a "walmart meet" and I was told to change the trans oil again still using MT-90 and that this time I should over fill it just a little and that this would fix my problem. Has anyone else heard or tried this?
Old Dec 30, 2008 | 09:29 AM
katafuji's Avatar
There are a few problems that must be addressed;
1) How is the clutch pedal free-play cold versus warm? Does it change as the chassis of the car warms up (as opposed to simply as the engine warms up)?
2) How many miles on the car?
3) BHR suggests street-driven RX-8s use Mobil 1 75W90 or, if you can find it, a GL-4 fluid. Racing fluids are not typically good for the street.
4) Does the clutch pedal make any noise as you push it?
1) the same cold and warm
2) 72K
3) My RX-8 is my only car, daily driver, autox, and drifter. I was told not to use the Mobil 1 75W90 because it is a GL5 and that GL5 is not good for the brass parts in the trans.
4) No
Old Dec 30, 2008 | 10:41 AM
zoom44's Avatar
some gl-5 use a sulfer additive to obtain the gl-5 rating. that sulfur was what is bad for the yellow metals. however if the GL-5 does not have that sulfur it is fine- and will most likely be noted on the label
this mobil1 LS gl-5 75-90 has the sulfur and i wouldn't recommend it for the tranny
http://www.mobil.com/USA-English/Lub..._LS_75W-90.asp
and neither would Mobil
Thank you for your inquiry,
Mobil1 LS 75W90 gear oil is an API GL-5 rated and should not be used in manual transmissions that require an API GL-4.
Thank you for choosing ExxonMobil products.
If you need further assistance, please contact ExxonMobil at 1-800-ASK-MOBIL
-Matt Jacob
Old Dec 30, 2008 | 10:46 AM
zoom44's Avatar
Pennzoil also says the same thing
File Type: pdf
Old Dec 30, 2008 | 11:14 AM
zoom44's Avatar
any gl-4 75-90 id say in particular
royal purple maxgear which meets gl-4 and gl-5 with no sulphur http://www.royalpurple.com/gear-oil.html
or amsoil http://www.amsoil.com/StoreFront/mtg.aspx?zo=515729
or redline mt90 http://www.redlineoil.com/products_g...7&categoryID=7
but pennzoil and mobil etc all make gl-4 75-90 that will do if you need to pick it up at the department store auto department
redlines gl5 75-90ns may be no sulphur but its hard to digest from their site and a chat is needed to confirm
Old Dec 30, 2008 | 12:56 PM
zoom44's Avatar
yeah OTC is fine for most people
Old Dec 31, 2008 | 12:15 AM
b&g..
WranglerFan
May 31, 2022 07:51 AM
WranglerFan
Nov 5, 2017 09:35 AM
Vedivan1
Sep 18, 2015 12:39 PM
teamdipngo
Sep 14, 2015 02:47 PM
