New MazdaManiac BASE Calibrations
Old Dec 23, 2008 | 08:53 PM
  #176
05rex8's Avatar
sold the 8... :(
I wish the effing snow would stop over here so I can do my datalogs for my second calibration
Old Dec 23, 2008 | 08:57 PM
  #177
MazdaManiac's Avatar
Originally Posted by 09Factor
11,000 th post ^^^ YEA
(yes, I have nothing better to do atm)
And that is AFTER the Esmiril thread got deleted, taking about 2 dozen posts with it.
I keep deleting stuff, but it piles up faster than I can get rid of it.
Old Dec 23, 2008 | 08:59 PM
  #178
ShellDude's Avatar
weeeeeeeeee
hey Jeff... how recent is the avatar picture? something looks different from when I saw you back in the Fall... and no, I don't mean the dog
Old Dec 23, 2008 | 09:07 PM
  #179
My hair grows at a rate of about 1" every 3 weeks, so I go from shiny to Sasquatch on a regular basis.
I don't know when I took that pic, but it was probably back in Spring.
Old Dec 23, 2008 | 09:17 PM
  #180
heyarnold69's Avatar
Rotary wanabee
Such speedy service!!!!
Old Dec 23, 2008 | 09:46 PM
  #181
For the AP of my facial hair?
Your logs are excellent. Spot on - stoich in cruise and only 2% trim at idle.
Old Dec 23, 2008 | 09:51 PM
  #182
hakuna matata!
So I sit here like a child on the eve of Christmas Eve waiting for a MazdaManiac calibration.
PS: I also realized how much I suck at wrapping christmas presents.
Old Dec 24, 2008 | 01:15 AM
  #183
hakuna matata!
Old Dec 24, 2008 | 04:05 AM
  #184
Grouch's Avatar
I didn't see my name on the list so I re-sent. No big rush since I will see you on the 17th anyhow tho
Old Dec 24, 2008 | 06:41 AM
  #185
L337fpc's Avatar
ლ(ಠ益ಠლ)
Me too alz0rz...
Old Dec 24, 2008 | 10:44 AM
  #186
Jasonawojo's Avatar
So true!
Jeff, I sent you a PM. I want to make sure this is the right calibration.
Old Dec 24, 2008 | 01:37 PM
  #187
alienRX8's Avatar
Boosted!!!
Yeah. Its my bday today too so I expect a present in the comming days Jeff!!
:D
Old Dec 24, 2008 | 06:58 PM
  #188
hakuna matata!
So Jeff, these last set of calibrations you sent out are they still comparable to stock? or are they the "performance" calibrations?
Old Dec 25, 2008 | 12:26 AM
  #189
What does it say at the bottom of the e-mail?
Old Dec 25, 2008 | 12:57 AM
  #190
hakuna matata!
Oh dur. Every time I load a new map you send me, the butt dyno says the car feels quicker already! I can only hope for the best when I do get a "performance" calibration.
Happy holidays!
Old Dec 25, 2008 | 01:25 AM
  #191
Happy holidays!
It probably is getting some power benefit since most of the calibrations I've done so far just to "dial in" have resulted in a significant correction to the target lambdas.
This next set of instructions that you have received with v4.0.2 has you do some WOT logging, so we'll see where your car sits now.
Old Dec 25, 2008 | 01:32 AM
  #192
hakuna matata!
Looking forward to it. Did my first drive cycle this morning and the second tonight. I'll do the logging tomorrow morning if I get a chance to and you'll have logs in the evening.
Old Dec 25, 2008 | 01:39 AM
  #193
No rush - I'm not doing any more calibrations until next week.
Old Dec 25, 2008 | 01:43 AM
  #194
hakuna matata!
Gotcha.
When we do finish the calibration process I'd like to do a realistic dyno of any gains.
What I'd like to know is how accurate would my readings be if say I did this: Uninstalled the AP, did a pull, then loaded my final AP tune and did another pull.
Would that be sufficient for an accurate representation of a before and after?
Old Dec 25, 2008 | 01:50 AM
  #195
Probably. There are still the effects of fuel trim (which we try to negate through this process), but it would affect both pulls.
The more accurate example would be to drive the car stock for a bit, do a pull, install the AP, drive the car and then do another pull.
I know that isn't practical, though.
Old Dec 25, 2008 | 08:05 AM
  #196
neXib's Avatar
New calibration, nice.
A question though. Seeing as I have the original cat, at what point should I worry about idle/cruise AFRs values and such, I have been monitoring them but am not sure where the "cat killing" values are.
The plan is to get a supercat or something in spring, not sure if I can go the midpipe route as I don't want the attention, the shiny blue car is enough :P
Old Dec 25, 2008 | 01:02 PM
  #197
CAT-killing is kinda hard to predict.
There are two scenarios where the CAT gets baked: lean cruise and lean WOT.
The lean cruise situation is probably the more damaging since it is sustained, but how lean is lean?
I'd say that if your cruise values stay between 13.9 and 14.7 or so you should only experience minimally shortened CAT life.
If your sustained cruise AFRs are touching 15 or staying even higher, let me know and I'll "fatten up" your cruise values on your final tune.
Those without a CAT will want to cruise at 15 or above up to the point where they experience surging.
Different cars react differently to lean cruise values, so feedback is necessary to tune lean cruise.
My car will cruise just fine all the way to nearly 17:1! Another car here in Phoenix was not happy beyond 15:1. I think Flashwing's car started getting finicky around 15.7:1.
Old Dec 25, 2008 | 06:57 PM
  #198
neXib's Avatar
Cool. I'll look at the values when I'm logging. I can write if I want the cruise "fattened up" in the additional info section if you read those every time?
Old Dec 25, 2008 | 11:40 PM
  #199
kersh4w's Avatar
Hit & Run Magnet
my 6 months went by and i never took advantage of the tuning calibrations because i think that all that tuning stuff is beyond me.
i still think so. maybe in time i can teach myself. it would help if the accessport software would install on my computer. i have vista 64 bit.
Old Dec 25, 2008 | 11:43 PM
  #200
05rex8's Avatar
sold the 8... :(
so what was the point of getting the AP if you didn't have MM make you any calibrations?
