Custom gauge pod
Old Dec 1, 2008 | 05:31 PM
CraigRX8's Avatar
CraigRX8
Custom gauge pod
Heres my attempt
buy cheap gauge pod. mark it up how you want.
cut off sides
cut
start fibreglassing. dont forget to rub down.
fill in with p38 easy sand, or any body filler
i got time to do a lil work on it today.
So i got it rubbed down, 60 grit, 120 grit, 320 wet and dry, then 600 grit. dont go any higher as you need the 2k or hi build primer to stick. once this is applied you can rub it down with 800, then 1200, then 1500.
so i got my plastic filler primer on.
just one coat so i can see where needs more filler
Old Dec 1, 2008 | 05:35 PM
Rotr8's Avatar
whines all the way home
looks good, try one of those wrinkle coats so it might match the texture of the interior
Old Dec 1, 2008 | 05:41 PM
CraigRX8's Avatar
CraigRX8
havent seen that, got a link to the stuff
Old Dec 2, 2008 | 04:09 AM
shakeyourbrakes's Avatar
hey give flat black primer a try..i sprayed my lotek pod with it awhile back after trying all kinds of color combos and it came out a perfect match to the interior once it dried
Old Dec 2, 2008 | 05:53 AM
SiLVeRE8's Avatar
a.k.a. WhITeRE8
nice work! have you ever think of painting it gloss black? i painted mine gloss black and loving it
Old Dec 2, 2008 | 05:55 AM
CraigRX8's Avatar
CraigRX8
poast up some pics
Old Dec 2, 2008 | 06:14 AM
SiLVeRE8's Avatar
a.k.a. WhITeRE8
Originally Posted by CraigRX8
poast up some pics
heres the link to my thread
https://www.rx8club.com/showthread.p...ighlight=gauge
Old Dec 2, 2008 | 07:54 AM
firebirdude's Avatar
User and Abuser
Isn't it facing the wrong way?
Old Dec 2, 2008 | 08:14 AM
CraigRX8's Avatar
CraigRX8
no my car is rhd
Old Dec 2, 2008 | 03:54 PM
cmr333's Avatar
SR Dubbed Rx8
if you want a texture get a heat gun and a satin black spray can. hold the can about 11 " away from what your spraying and point the heat gun at an angle to what your spraying. this will create a dry spray effect and give it somwhat of a texture.
Old Dec 2, 2008 | 04:21 PM
nvrfalter's Avatar
tonybob failpants
piano black FTW. looks real nice dude.
Old Dec 2, 2008 | 05:16 PM
Rotr8's Avatar
saw this stuf in AutoZone last week, they didnt have flat black but just pick any color and then sray it with flat black
http://www.thewinningfinish.com/plas...=WrinkleFinish
http://www.google.com/products?hl=en...num=4&ct=title
Old Dec 2, 2008 | 05:37 PM
CraigRX8's Avatar
CraigRX8
is there a paint code for piano black. wrinle paint wont work, it would need to be vinyl paint. wrinkle paint will wrinkle and non of the dash is wrinkled
Old Dec 2, 2008 | 06:38 PM
nvrfalter's Avatar
tonybob failpants
its just gloss black really.
Old Dec 2, 2008 | 06:51 PM
SiLVeRE8's Avatar
a.k.a. WhITeRE8
well i forgot what the paint code was but its called jet black. and i think any gloss black with match
Old Dec 2, 2008 | 06:54 PM
05rex8's Avatar
sold the 8... :(
I use this stuff at work all the time, works great
Texture Coating
Duplicates the original finish on plastic bumpers, instrument panels, dashes, consoles and other textured plastic and vinyl parts. May be topcoated with FLEXIBLE BUMPER COATER, COLOR COAT or most refinish materials. No priming required.
http://www.tcpglobal.com/autobodydep...emno=SEM+39854
Old Dec 2, 2008 | 09:43 PM
cmr333's Avatar
SR Dubbed Rx8
+1 thats good ****..the satin black paint i did my pod with is from sem
Old Dec 9, 2008 | 08:22 AM
CraigRX8's Avatar
CraigRX8
ok got the finger out....
drying infront of the oven on under 80oF
Everthing was really smooth id say ive spend in excess of 7 hours rubbing this thing down.
First of 3 coats of paint, then leaving it for 24 hours before lacquering it
Old Dec 9, 2008 | 08:35 AM
User and Abuser
Forming looks great. Still a little early to make a call on the finish..... but awesome job so far!
Old Dec 9, 2008 | 12:01 PM
wow, awesome work so far! can't wait to see the finished product.
Old Dec 9, 2008 | 02:38 PM
seikx8's Avatar
Is this title ok?
Congratulations on the DIY gauge pod, it looks way better than mine
if you do flat black, DO NOT use clear coat. If you do the piano black, you might want to paint the air vent as well to match the entire center section.
Here is mine latest version with plain flat black, didn't do a good job of smoothing out the edges (was impatience):
And this is my first version with semi-gloss piano black, interior color matching is way off:
Old Dec 9, 2008 | 05:03 PM
nuke0907's Avatar
Never Blend In
seikx8, do you have any pics from the top and back of the pod?
Old Dec 9, 2008 | 05:51 PM
CraigRX8's Avatar
CraigRX8
Thanks, btw first pic looks a pretty good match. did you use a textured coat first?
Old Dec 9, 2008 | 09:07 PM
cmr333's Avatar
SR Dubbed Rx8
looks pretty good dude. its always nice to come up with somthing other people dont have for mad cheap.
Old Dec 9, 2008 | 09:16 PM
lookin' good... I wish I had the time/patience to do custom work like this
