2005 RX-8 Won't Start
Old Dec 1, 2008 | 06:12 AM
confutatis's Avatar
The car has been running fine. Sat a few days over the holiday weekend. I got into it this morning, turned the key, starts cranking, but no start. I'm wondering if it's flooded, and if so, is there anything I can do except call for a tow to the nearest Mazda dealer? Doesn't seem likes it's firing at all.
David
Old Dec 1, 2008 | 01:01 PM
Old Rotor's Avatar
David
Type "DIY flooded" in the search at the top and find your answer.
Old Dec 1, 2008 | 01:34 PM
Silver06's Avatar
Zoom Zoom....
Hi.
I agree with Old Rotor. Flooding is a great place to start.
Before you tow to the Dealer, have a look at the procedure that the Mazda Dealer will do. http://www.finishlineperformance.com...5-08-1883f.pdf
Also, are you M/T or Auto? If M/T and you're on a hill, or have some folks to push your car, some have had success with the push start method of clearing flooding.
Good luck.
Old Dec 1, 2008 | 03:58 PM
Go48's Avatar
Try the de-flooding procedure in your owners manual. It may take several tries, but it should eventually work.
Old Dec 1, 2008 | 10:05 PM
GODFATHER's Avatar
Iraqi Freedom Veteran x2
your car is covered for "no starts" for 8 years or 100k miles... tow it to the dealer and they will do it for free.... trust me i know.... i do this on a daily basis. and you'll get some new plugs....
Old Dec 2, 2008 | 01:55 AM
Silver06's Avatar
Zoom Zoom....
Uhmmm, no it isn't.
Old Dec 2, 2008 | 06:25 PM
Nubo's Avatar
Lubricious
Originally Posted by Silver06
Hi.
Good luck.
Your mileage may vary, but when I finally did get a flood (my own fault), I found that instead of the entire procedure, simply following the step of adding some oil to each intake port resulted in a successful (albeit smoky) start.
Old Dec 11, 2008 | 10:42 PM
GODFATHER's Avatar
it wasn't covered a few months ago now it is covered for 8 years and 100,000 miles........ like i said i know things that are put out by mazda before most of you all do..... and yes i said most.... some people have connections too...... matt sorry if you got the no start tsb done before this changed but now as in today if you go to a mazda dealer that isnt shady which alot of them are and it sux to say that bit the no start and lack of power tsbs are covered under warranty for 8 years or 100k
Audio Concepts ATL
Sep 26, 2021 01:59 PM
SIllver
Aug 1, 2015 07:34 PM
Davey's RX-8
Jul 28, 2015 12:13 PM
harithac
Jul 25, 2015 04:21 PM
Peanutbuttertruffle
Jul 24, 2015 07:49 AM
