which wires are the 0-5v and ground wires on MAF sensor harness?
Old Nov 17, 2008 | 09:20 PM
13bturbofc's Avatar
400whp RX-7+05 RX-8=BROKE
Question which wires are the 0-5v and ground wires on MAF sensor harness?
im installing a meth injection kit that runs off of the 0-5v output from the mass air flow sensor. so the instructions say i need to wire the 0-5v hot wire and the 0-5v ground wires from the MAF sensor...anyone have a diagram or know the colors of which wires these are on the MAF harness?
Old Nov 18, 2008 | 12:29 PM
13bturbofc's Avatar
so far im hearing that the yellow with red stripe wire should be the 0-5v hot and the ground is black with green stripe..can anyone confirm this?
Old Nov 18, 2008 | 03:33 PM
hakuna matata!
Here you go.
Old Nov 18, 2008 | 04:11 PM
13bturbofc's Avatar
awesome man thanks... so the black with green stripe is definitely the ground but which one is the 0-5 v hot that i need? what does the number 5 with the letter next to it represent? one says 5v the other says 5n and then 5k. does the 5v mean 5 volt?
Old Nov 18, 2008 | 05:08 PM
MazdaManiac's Avatar
Try the one that says "MAIN RELAY". lol
Old Nov 18, 2008 | 05:52 PM
13bturbofc's Avatar
seriously? im a newb when it comes to certain electrical things... not sure why the maf have a main relay.. excuse my newbiness but after all thats what this forum is for
Old Nov 19, 2008 | 10:59 AM
13bturbofc's Avatar
bump..i really need this answered i dont know if mm was just ****** with me or not..so im still looking for an answer
Old Nov 19, 2008 | 09:40 PM
13bturbofc's Avatar
lol... anyways... how come OD's meth system is wired to the yellow with red stripe and he says it works?...
Old Nov 19, 2008 | 10:48 PM
Because that's the MAF output, not the power wire.
Old Nov 20, 2008 | 06:56 AM
13bturbofc's Avatar
for future reference can you tell me how that diagram tells me what the 0-5v output is, or doesn't it?...
Old Nov 20, 2008 | 08:55 AM
secret8gent's Avatar
the enemy in the mirror
well it would if you were looking at the 'whole' thing.
here's a relevant snippet just for you.
Attached Thumbnails which wires are the 0-5v and ground wires on MAF sensor harness?-maf-pinout.gif
Old Nov 20, 2008 | 08:53 PM
13bturbofc's Avatar
well i was just thinking.... the 0-5v is a hot wire correct? and we were calling it that cause we were comparing a ground to a wire with voltage
Old Nov 20, 2008 | 09:33 PM
"hot" always means power.
"signal" means the output of said device.
Old Nov 20, 2008 | 10:55 PM
13bturbofc's Avatar
yeah he knew wat i ment too....and in my book hot can mean any wire with voltage but power always means power and signal always means signal.. i never said power wire.but i digress thread closed...
Old Nov 20, 2008 | 11:23 PM
"Hot" ALWAYS means power.
It NEVER means signal.
Now, you can say the signal is hot, but you have to specify it as the signal first.
Old Nov 21, 2008 | 06:52 AM
13bturbofc's Avatar
hot means voltage , it is used much more commonly to describe a power wire but it can mean any wire with voltage especially when your comparing it to a ground...Miriam Websters agrees..."Charged or energized with electricity: a hot wire"
Old Nov 21, 2008 | 10:51 AM
So, you've got two wires to choose from.
One is carrying about a volt and the other is carrying 5 volts. Which is the "hot" wire?
You are arguing a moot point.
You thread failed because you asked the wrong question.
Everyone that attempted to answer you did so based on your improper use of the word "hot".
That should be all the evidence you need to see where you screwed up.
Oh, and I can play that game too.
Dictionary.com:
25. actively conducting an electric current or containing a high voltage: a hot wire.
First, a signal is neither "conducting current" (it is a varied voltage at a fixed current) nor is it a "high voltage", even in relative terms in a 12 volt system.
Even at its maximum output, the MAF signal is less than the supply of 5 volts.
Old Nov 21, 2008 | 04:37 PM
zoom44's Avatar
thread closed. 13bturbofc leave teh name calling out of your posts from now on.
ÜberJumper
Canada Forum
21
Feb 20, 2025 11:57 AM
JimmyBlack
273
Feb 10, 2020 10:23 PM
DVerdeyen
Sep 13, 2015 11:19 AM
iwannarun
Sep 6, 2015 01:37 PM
