Having a PROBLEMM any ideas what it is???
Old Nov 4, 2008 | 05:46 PM
mainevent1120's Avatar
hey guys im away at college right now and was home about 2 weeks ago drving my 8 and everytihng was fine. This past friday my dad moved it into the garage before going away for the weekend and everything was fine then too. When he got home yesterday went to go start it and it wouldnt start. He figured it was the battery and went and go a new one and changed it today and still will not start. It is a 2004 6 speed. I have a full agency power exhaust on it and thats it. If you guys have any ideas what it could be could ya let me know.
thanksss
Old Nov 4, 2008 | 05:48 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
Yeah.......he flooded it!
Do you have an owners manual? There are several ways to try and deflood.
Some are easy, some not so easy.
This is the not so easy one. http://www.finishlineperformance.com...5-08-1883f.pdf
Old Nov 4, 2008 | 05:50 PM
invasion08's Avatar
+1 on the flood
Old Nov 4, 2008 | 05:53 PM
what do you mean flooded?
Old Nov 4, 2008 | 05:58 PM
invasion08's Avatar
If you turn off the car before is reaches operating temp, it will cause the unburnt fuel to wet the spark plugs making it unable to produce spark aka flooding. That is just the simple understanding of flooded
Mazurfer's Avatar
Can you read the pdf file that I linked? Read the first part.
This car doesn't like being started and then shut down before reaching normal operating temperature. It's in your manual for the car.
What.............no manual? Go to www.mazdausa.com under the owners section and get a free download of it. Yes, you will have to register, but it's worth it.
Anyway, the first step is try holding the gas pedal to the floor and crank it for ten seconds, let go, and then try to start as normal.
If that doesn't work...then............open up the fuse box and remove the fuel injection fuse (don't know which one it is), just look it up and I'm sure you'll find it. After removing that, crank it but don't crank it over 8-10 seconds. If it doesn't turn the first time, it should turn the second. After it starts, a crap load of smoke will come out of the rear............but thats normal. After it starts and you burn the remaining fuel in the engine, dont forget to put the fuse back.
If that doesn't work, then see that first link I provided in my first reply.
Above and beyond all...............DO NOT start the car and then shut it off before the temp gauge reaches close to where it normally sits.
A lot of people will bump the idle up to 3,000 rpm before shutting it down, but I don't. I just never, ever, shut it off cold!
Old Nov 4, 2008 | 06:00 PM
invasion08's Avatar
Wet fouled plugs can also prevent an engine from starting, but in many instances the fouling problem has nothing to do with plug wear or neglect. If an engine is flooded with fuel while it is being cranked, gasoline can soak the plugs and bleed off the ignition voltage before it forms a spark. On fuel injected engines, wet fouling is less of a problem but can happen if a cold start injector leaks or there's a fuel calibration problem that creates an overly rich startup mixture. The cure in all cases is to wait for the plugs to dry out, or to remove the plugs and clean or replace them.
Old Nov 4, 2008 | 06:01 PM
invasion08's Avatar
If you need new plugs www.autopartswarehouse.com has all 4 plugs shipped for $85 dollars. Best deal i know of
Old Nov 4, 2008 | 06:03 PM
okay thank you guys very much...i made sure to tell him to let it warm up before he moved it or anything
thank you
Old Nov 4, 2008 | 06:12 PM
Easy_E1's Avatar
Sherlock Holmes solves another mystery.
Old Nov 4, 2008 | 06:35 PM
i just tried these ways and it did not work...when he pulled out the fuses there was one for fuel he tried for and a fuel pump fuse...tried with each one out at a time but did not work...still wont start....he said that it doesnt smell like gas as much anymore so could that mean that it is working??
92trbolzr
May 18, 2025 09:04 AM
Jazzmeson
RX-8 Multimedia/Photo Gallery
11
Mar 2, 2016 02:25 PM
Digitz0070
Oct 7, 2015 12:43 PM
Zube6115
Sep 30, 2015 12:57 PM
tommy26Germany
Sep 29, 2015 10:33 AM
