remote wire
Old Oct 24, 2008 | 06:37 PM
pup's Avatar
pup
holla if u hear me
remote wire
what up everyone.....i am installing an amp in my 04 rx-8......is there a way around running a remote wire from the factory head unit....every one i have installed ran from an aftermarket head unit....never encountered this and i want to keep the unit stock......thanks in advance
Old Oct 24, 2008 | 07:30 PM
Socket7's Avatar
ಠ_ಠ
There sure is a remote line! it's on the connector to the Bose amp in the trunk. The audio install guide sticky has all the info you need, so get researching!
Old Oct 24, 2008 | 08:03 PM
rollerbldes's Avatar
If you don't have bose.. then you could get it from the accessory power plug.
Old Oct 24, 2008 | 08:06 PM
Renesis07's Avatar
Vtak just kicked in yo!!
I have bose and I get it from an accessory plug
Old Oct 24, 2008 | 08:34 PM
pup's Avatar
pup
holla if u hear me
i do have the bose system....where do i find the audio install guide.....
Old Oct 24, 2008 | 08:44 PM
firebirdude's Avatar
User and Abuser
the yellow/white and pink/black wires are hot only when the key is in the acc mode (Bose amps inputs)
Old Oct 25, 2008 | 12:11 AM
Socket7's Avatar
ಠ_ಠ
I tried it that way and got a thump when i turned off the car.
Old Oct 25, 2008 | 01:41 AM
SiLVeRE8's Avatar
a.k.a. WhITeRE8
i get mine off the rear cigarrett lighter
Old Oct 25, 2008 | 08:40 AM
Renesis07's Avatar
I used to get that with my old Kenwood amp, for whatever reason my JL amp doesnt do it anymore, problem solved!!
Old Oct 29, 2008 | 01:58 PM
echotec's Avatar
the thump your getting is called a turn off pop, it's caused by two units powering off at different times. The only way to remedy this without compatible units is to "SHORT" the inputs of the amp when the amp turns off. That’s what the store bought modules do https://www.autotoys.com/x/catalog/N...OR_p_1812.html
or you can wire one up yourself with a 4 pole double throw relay wired into your remote line and some RCA ends wired into the amp RCA inputs. The object would be to connect the inputs together so no external signal is introduced.
cliffkemp
Dec 24, 2024 10:48 AM
tjohnmeyer
Sep 28, 2017 05:03 PM
Danield97
Sep 30, 2015 05:59 PM
jer2911
Sep 29, 2015 06:37 PM
Learners_Permit
Sep 27, 2015 07:38 PM
