Brettus Turbo install thread
Old Oct 29, 2008 | 05:03 AM
  #26
yushinrt's Avatar
Originally Posted by Brettus
it's a 6 speed 6port
today was a waste - got nothing done
my bad
Old Oct 29, 2008 | 03:12 PM
  #27
Brettus's Avatar
Boosted Kiwi
Getting set up
Out they come
Tight as a fishes **** in there !!!!
Old Oct 30, 2008 | 03:40 PM
  #28
Brettus's Avatar
Boosted Kiwi
Finally getting somewhere now . Should have it running later today or tomorrow .
Took most of yesterday to get the fricken pipes around the steering shaft - I'm sure the kit must be different for RHD cars ....
Old Oct 30, 2008 | 03:45 PM
  #29
how'd you solve the plumbing issue? Glad you're making progress!
Old Oct 30, 2008 | 03:47 PM
  #30
Brettus's Avatar
Boosted Kiwi
I post up the tools i used later - that will give you some idea lol
Old Oct 30, 2008 | 03:58 PM
  #31
cheeto's Avatar
has money, but unsure
that would be a great help.
Old Oct 31, 2008 | 06:47 AM
  #32
Brettus's Avatar
Boosted Kiwi
No photos of the tools - suffice it to say that a sledge hammer was involved.
See the pipe below - I had to squash it to get it to clear the steering linkages . Also had to grind away some of the power steering bracket and take to one part of the bodywork with a sledge hammer .
Pic does not show it well but it all clears now ...
And for the money shot
Old Oct 31, 2008 | 06:49 AM
  #33
yushinrt's Avatar
so is all fitting on to the car ? brettus congrats
Old Oct 31, 2008 | 07:00 AM
  #34
Brettus's Avatar
Boosted Kiwi
IT"S ALIVE
Started it up tonight She fired right up first try .
Had no maps to work with so had to start from scratch with the tuning. It's a cool night so i've been able to get away with some lean mixtures till I dial it in .
I had to pick up my daughter from a party at around 11.00pm and as I pulled up to the house a group of guys called out - "Hey is that turboed ? "
"What makes you think that ?" I said
"We could hear the blowoff valve , man that's one very cool car you got there."
Heh - and I was going for the stealth approach !
Only issues I have so far are a leaking gasket between cat and downpipe and the hose clamp on the inlet hose to the turbo has slipped off . I had to get the pipe modified to clear the steering column - I bloody knew I should have got them to weld a bead around the end of it while it was there
  #35
mysql's Avatar
Doppelgänger
Hey Brettus...
I have bad news for you. Turbos generate more heat than superchargers and the boost is harsher on the engine. It was a prank 3 years in the making, but it was so worth it. lol
It's looking great.
Old Oct 31, 2008 | 07:09 AM
  #36
Brettus's Avatar
Boosted Kiwi
Originally Posted by mysql
Hey Brettus...
It's looking great.
Oh **** - now you tell me
Old Oct 31, 2008 | 09:49 AM
  #37
Kane's Avatar
Senior Member
Woot!!!
Congrats man.
Old Oct 31, 2008 | 02:14 PM
  #38
yushinrt's Avatar
[B]
i thort you plumed your blowoff valve ? so you can't hear it ?
so what sort of sound does your blow off valve make pusshhhhhh or kululululu noise ?
Old Oct 31, 2008 | 04:07 PM
  #39
kersh4w's Avatar
Hit & Run Magnet
kululululu?
Old Oct 31, 2008 | 05:43 PM
  #40
rotarenvy's Avatar
video or it didn't happen
congrats brettus!
Old Oct 31, 2008 | 05:53 PM
  #41
Brettus's Avatar
Boosted Kiwi
heh - wondering how long it would be before the video remark .
I'm still running on low boost ATM (4-5 psi) and tuning with the Powermod . On Tuesday I'm getting flashed by Hymee - well we are going to use Hymees' Protuner with a SC map as a base . Once I am able to go WOT at 8 PSI i'll do the vid
Old Oct 31, 2008 | 06:41 PM
  #42
On Tuesday I'm getting flashed by Hymee - i'll do the vid
uh, that sounds kinda dirty, but if you are willing to do a video, well?
btw, great support... hymee is in the game. glad it is going well..
Old Oct 31, 2008 | 07:15 PM
  #43
rotarenvy's Avatar
hymees base map should work well out of the box (so to speak). I'm using hymee's tuning package also and it worked wonders for me.
I would still suggest holding on to the power mod and tuning it to the 8psi to see what works and transfer it over to the flash: only because I feel std alone managements tend to be easier to tune on a dyno in real time. however I have been known to be wrong :D
Old Oct 31, 2008 | 11:00 PM
  #44
Brettus's Avatar
Boosted Kiwi
Some good and bad news
Found I have a pinhole in the greddy manifold - the good news is it can be got to without taking anything apart .
Would brazing be a good way to repair this ?
Also have found the Powermod does not give me a fine enough adjustment to keep the afrs steady
Old Oct 31, 2008 | 11:18 PM
  #45
Brettus's Avatar
Boosted Kiwi
Only you would make that comment LOL
don't think hymee would apreciate his flash being posted - either way
Old Nov 1, 2008 | 12:49 PM
  #46
Kane's Avatar
Senior Member
A pinhole? Did you buy the kit used?
My gut says no to brazing;since the temps get so high in this location - but I am not really an expert so who knows.... But I would weld.
Old Nov 1, 2008 | 02:01 PM
  #47
Brettus's Avatar
Boosted Kiwi
yes - used kit so no comeback on Greddy ....
I'm wondering about just leaving it - it's probably smaller in dia. than a pin ....
Old Nov 1, 2008 | 02:03 PM
  #48
Kane's Avatar
Senior Member
That would be unprofessional....
Plus it can cause some heat issues in the engine bay.... I think you are gonna need to bite the bullet on this one.
Old Nov 1, 2008 | 02:07 PM
  #49
mysql's Avatar
Doppelgänger
the manifold may expand as it heats up and closes the hole when the vehicle is warm.
a small hole will make a lot of exhaust noise though. If you can't hear it, then I wouldn't worry about it.
Old Nov 2, 2008 | 02:42 AM
  #50
Brettus's Avatar
Boosted Kiwi
OK - very excited right now . Just did my first WOT pulls up to 6000rpm - f**k this thing is exhilarating to drive - very impressed .
Engine runs as smooth as silk
Still only at 5 PSI !!!!
