My 8 won't start ;/
Old Oct 18, 2008 | 08:48 AM
Ryoma-kun's Avatar
My 8 won't start ;/
Tried to start my Rx-8 192 HP Manual today but no way it would :| The lights and everything turns on but it just won't start. It makes a weird wheezing noise when I try but no ******* way it will start. Is it dead?
Old Oct 18, 2008 | 08:58 AM
ferg's Avatar
192hp? lol maybe its flood, hold down your gas and cluch at the same time and hold down the key for a min, after that let go and turn it on normal
Old Oct 18, 2008 | 09:00 AM
Renesis07's Avatar
Vtak just kicked in yo!!
192? Is that a 5 spd?
Old Oct 18, 2008 | 09:05 AM
musclecarconvrt's Avatar
Try two things. First, the de-flooding procedure in the manual. Second, check the coils by hooking up a simple inductive timing light to each plug wire to see if it's getting any fire. Beyond that we need more information.
Was it running fine before?
How did you shut the car off the last time it did run? Was it fully warmed up or did you move the car for a wash or something and shut it off cold?
Is you car still under warranty?
Did you install any mods?
"Wheezing noise"? Please elaborate.
Old Oct 18, 2008 | 09:39 AM
Ryoma-kun's Avatar
Yeah was properly warmed up. Just parked it as normal. Yeah it is a 192 HP 5 speed manual. No mods, 24.900 KM on it 2005 model. Don't really know how to explain the sound. Don't know how it can be flooding seeing it was for sure properly warmed up.
Old Oct 18, 2008 | 04:43 PM
RotoRocket's Avatar
Freely Radical
I can 95% guarantee you it's the battery.
Get a jump from someone.
The fact that the dash lights and other things light up means nothing.
Your car is an automatic or a manual. The manual makes 232 horsies, and the automatic makes 197.
Old Oct 18, 2008 | 04:49 PM
Ryoma-kun's Avatar
I don't know how many times I have to explain that Europe has got a 5-speed manual version too.
Old Oct 18, 2008 | 05:35 PM
j67345's Avatar
Same thing happened to mine last year....I thoght it was flooded, but the fuel pump had died. Replaced under warranty.
Old Oct 18, 2008 | 09:37 PM
superglue's Avatar
n00b post whore
I've heard of the 5 speed version, but what's a Europe?
Old Oct 19, 2008 | 03:34 AM
Ryoma-kun's Avatar
O_o ?
Old Oct 19, 2008 | 06:27 AM
StealthTL's Avatar
Metatron
Take out the plugs and dry them with solvent, if wet.
Turn engine over, foot hard on the gas, with plugs out. This will purge any free fuel out.
Plugs back in, get a boost and good luck.
S
Old Oct 19, 2008 | 07:47 AM
Ryoma-kun's Avatar
Uh but it's not flooded.
Old Oct 19, 2008 | 08:05 AM
1QWIK7's Avatar
How do you know its not flooded?
Im sure your attempts of trying to make it start have caused the engine to flood.
I would suggest doing the un-flooding procedure. Then have a good charged battery and crank it one more time.
Old Oct 19, 2008 | 03:32 PM
Ryoma-kun's Avatar
Ehm but then again, why didn't it start in the first place?
Old Oct 19, 2008 | 05:46 PM
Look friend, at this point you can either:
A. listen to the advice given (flooded, low battery, coil ect.)
B. give more information
C. call the dealer and let them sort it out.
You choose. We tried to help you.
Old Oct 19, 2008 | 07:51 PM
1QWIK7's Avatar
Idk, you tell us.
You either had it running prior to the initial no start by not letting warm up which would cause it to flood for the next time around.
OR
You had the car sitting, maybe the battery became weak.
Old Oct 19, 2008 | 11:47 PM
Ryoma-kun's Avatar
Originally Posted by 1QWIK7
Idk, you tell us.
OR
Yeah indeed, that would be the obvious explanation to the problem. But in this case, I had it running for an hour or so before turning it off, and the car had been parked for half a week or so before I tried to start it up. Nothing abnormal if you ask me. But yeah, it's fortunately parked by my Mazda dealer so I'll make them look at it today. Thanks for helping anyway.
Audio Concepts ATL
Sep 26, 2021 01:59 PM
drebbrnator
Dec 27, 2018 07:02 PM
Modern2Strokez
Aug 16, 2015 01:07 AM
Davey's RX-8
Jul 28, 2015 12:13 PM
harithac
Jul 25, 2015 04:21 PM
