would this work for us?
Old Oct 16, 2008 | 01:54 PM
JGR4444's Avatar
GR
Would this procedure work for the rx8? because i had to take my cat out and put a straight pipe on there and my car is running like crap because it is dumping way to much fuel in there and my check engine light is on
http://www.msprotege.com/forum/showt...hp?t=123634664
Old Oct 16, 2008 | 02:16 PM
How do u know its dumping too much fuel ?
and its the front O2 sensor that gives o2 feedback to ecu. So that might be a problem ?
Old Oct 16, 2008 | 05:19 PM
JGR4444's Avatar
GR
i really dont know... my car sounds like a lawn mower right now... it has no torque and it bogs so easily... i dont know what is going on i cant figure it out... i had a shop weld a straight pipe onto my exhaust because mazda stole my cat and i dont have the money for a new one... im not sure what is going on with me car right now
Old Oct 16, 2008 | 05:23 PM
quazmosis's Avatar
Chode
Let's have some more specs on your car. MT or AT. Miles? Could be the usual coils and plugs.
Old Oct 16, 2008 | 05:28 PM
olddragger's Avatar
he just replaced his own engine.
if you are dumping fuel--check your injectors--make sure they are ok and hooked up right. check all your vacuum lines and the maf--do the check list
OD
Old Oct 16, 2008 | 07:26 PM
JGR4444's Avatar
GR
yea as stated i just put a 20k motor from a 2007 rx8 into my 2004 rx8 without a cat and its running very sluggish... and sounds terrible.. its a 6 speed touring... really just seeking anyone who has any ideas really
thanks
Old Oct 16, 2008 | 08:12 PM
make sure ur injectors are in correct order.
Old Oct 16, 2008 | 09:00 PM
JGR4444's Avatar
GR
yea im checking injectors and coils tomorrow to make sure everything is set up correctly... ill let you know.. thanks for the help
TeslaMSI
Dec 10, 2015 01:10 AM
GARCIAC951
Sep 10, 2015 07:17 PM
ed0128
Sep 9, 2015 04:50 PM
mattymack
Sep 6, 2015 10:33 PM
ion_four
Jul 30, 2015 09:48 PM
