porting
Old Oct 9, 2008 | 11:36 AM
ira1377's Avatar
porting
im thinking of a street porting, any one have any experiance with mazsport, or maztech in tampa. Any other suggestions welcome
Old Oct 9, 2008 | 12:16 PM
CyberPitz's Avatar
Huge hole is huge
If I'm not mistaken, they didn't make porting on this engine very worth while. The way the ports are shaped and such...you won't be getting a big enough bang.
Correct me if I'm wrong, though.
Old Oct 9, 2008 | 12:33 PM
Falken's Avatar
Drop it into 3rd
Doesn't work to well with the MSP because you hit the water jacket before you get anywhere.
Old Oct 9, 2008 | 12:42 PM
mysql's Avatar
Doppelgänger
you can also remove too much material causing issues with the seals.
your intake ports are already as large as ported rx-7 engines. exhaust is the only thing you can change, but you can't change enough to make it worthwhile.
only exception is if your engine is already apart and you want to round off some of the edges a bit.
mazda spent quite a while looking at the exhaust ports since they're redesigned from previous rotary engines..
Old Oct 9, 2008 | 01:02 PM
CyberPitz's Avatar
Huge hole is huge
There's a reason the same sized engine is pushing that much more hp...they already did some decent ports.
Old Oct 9, 2008 | 03:34 PM
ira1377's Avatar
thanks for your info looks like fi for me
Old Oct 9, 2008 | 04:51 PM
8 Maniac's Avatar
Senior Member
https://www.rx8club.com/series-i-aftermarket-performance-modifications-23/ultimate-n-setup-8-a-115025/page2/
to answer your question, if I were to do the porting myself using the sand, I would use the coarse sand.
again, not responsible for any damages from porting the car with sand
Old Oct 9, 2008 | 05:04 PM
CyberPitz's Avatar
Huge hole is huge
Originally Posted by 8 Maniac
https://www.rx8club.com/showthread.php?t=115025&page=2
Damages? What damages? *Pours in sand...*
*Car begins to explode*
Old Oct 9, 2008 | 05:09 PM
tubingchamp's Avatar
What mawd bug?
Well, you could always just bore THROUGH the water jacket and build a bigger water jacket around the block for ultimate custom power.
Old Oct 9, 2008 | 07:51 PM
ira1377's Avatar
course it is, after taking the intake off would you then force it through with a 150 or 200 shot
Old Oct 9, 2008 | 07:55 PM
8 Maniac's Avatar
Senior Member
I've only gone with a 55 shot so far... dont want to get too crazy and blow the engine.
Old Oct 9, 2008 | 09:05 PM
ira1377's Avatar
can i offer peace offering i realize i was being an a@@ that night. i just want to mod my 8 and am thinking of different ways other than just throwing a turbo on it
Old Oct 9, 2008 | 09:45 PM
remixlp's Avatar
cobb AP
full exhaust
intake or CAI
you can start there or if you track your car then you can look into various suspension upgrades.
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
Evan Gray
Nov 24, 2015 01:00 AM
bosstin87
Oct 5, 2015 06:52 AM
Stubbs
Sep 27, 2015 04:06 PM
Evan Gray
Sep 26, 2015 12:30 PM
