Overheating
Old Sep 29, 2008 | 12:17 PM
drchris6000's Avatar
Overheating
Recently my 04 6spd 8 has been overheating intermittently. Basically whenever I idle for long periods of time, like traffic. I assume the fans aren't coming on, I just ordered a new thermostat. Does anyone know where I could find instructions for replacing this? And also does anyone know what else might cause the fans to not turn on; relay issue, fan control switch, etc...??
Old Sep 29, 2008 | 12:39 PM
check the fuses for the fans.
How do you know it's actually overheating? Is the stock gauge moving?
That guague wont' even move until you're sitting at over 230 degrees (it's more or less a 'dummy' gauge)
Old Sep 29, 2008 | 11:09 PM
mazdaverx7's Avatar
RX-Heaven
if the t-stat were bad your engine would overheat/overcool all the time. i wold look into the fan switch and the actual fan motors as being the culprit. how often are you experiencing this problem?
Old Sep 30, 2008 | 08:17 AM
It overheated on me 3 times... the gauge pinned and it started to boil over... all three times it was when I was stuck in traffic idling for long periods of time.... I checked the fuses and the relays.
Old Sep 30, 2008 | 09:18 AM
It should not overheat like that.
Thermostat is not that hard to replace, its just hard to take it out of its location cuz there are engine harness and some the mount above.
When was the last time you replace your coolant ?
Old Sep 30, 2008 | 10:29 AM
rx8-rus's Avatar
I had the same problem this summer. I replaced termostat and temperature sensor. It didn't help. Finally I replaced coolant reservoir cup, and this finally helped.
In this car there is no radiator cup, that keeps cooling system under pressure. Coolant reservoir itself is under pressure, and its cup has to keep it. So in case of overheating you need to replace cup first and then reservoir, since it is made of plastic and may deform.
By the way in my case engine temperature didn't exceed 212 degrees until it started boiling.
I checked temperature using CAN scanner. It rise to 212 and coolant started boiling at that time. If I new that there is no radiator cup before that, it would save me money spent on termostat and temp sensor replacement.
Now temperature gets as high as 230 degrees in stop and go traffic, but without coolant boiling.
Old Sep 30, 2008 | 11:19 AM
that is NOT good.
how long since you flushed the coolant out?
are you still in warranty?
random thought: have you relocated your license plate?
Old Oct 1, 2008 | 10:51 AM
haha with the random thought... I just did..... but it's not blocking anything, it's way out of the way.
I guess I'll just start replacing stuff till something works.
Old Oct 1, 2008 | 11:06 AM
where is the plate? I only ask because a local member here relocated his license plate and it caused overheating issues.
Old Oct 2, 2008 | 12:35 AM
do the fans run? or can you spin them with your hand?
btw, replacing stuff till i works always fails..
bees
Old Oct 2, 2008 | 08:10 AM
The fans aren't running, that's why I guessed it to be the thermostat or a fan control switch. I need to find some instructions on how to replace the thermostat.
Old Oct 2, 2008 | 08:15 AM
luis@championsmotorsports's Avatar
id say replace your oil and filter as well if the thing got that hot 3 times thats not good on your oil.good luck.
Old Oct 3, 2008 | 02:27 AM
thermostat has nothing to do with this.. fuse, or fans have failed. or something has stopped the fans from turning..
check to see if you can spin the fans by hand. if not look for rocks or something stopping the fans from turning.. it has happened before..
Old Oct 3, 2008 | 09:54 AM
RX8BANGLA's Avatar
RX-8 with no Mazda Dealer
I changed my water pump pully to Greddy and also filled in new coolant with the factory coolant. Since then engine overheats within 5 minutes of driving. It overheats fast if I turn the A/C on. Average outside temp is 44 degree celcius with 95% humidity.
Any idea why this is happening?
Old Oct 3, 2008 | 02:09 PM
Well I fixed it... it was the fan control switch, and a fuse.... the fans kick on now.... didn't bother replacing thermostat.
Old Oct 3, 2008 | 03:15 PM
^ glad to hear it's all fixed!
Old Oct 5, 2008 | 07:27 PM
mazdaverx7's Avatar
RX-Heaven
me too!! i figured it may be the fan not kicking on. which fuse was blown?
Luiss7
54
Aug 20, 2019 08:56 AM
Silver_Excalibur
23
Jun 6, 2019 07:23 PM
tommy26Germany
Sep 29, 2015 10:33 AM
iwannarun
Sep 6, 2015 01:37 PM
