Ultra n00b question re: Standard Bose HU
Old Sep 24, 2008 | 01:37 AM
deanrx8's Avatar
Okay,
I have been reading the forums, and I'm completely confused by all the jargon and part numbers and what can and can't be done...
I have a BOSE in Dash 6 CD Stacker... and the sound quality is pretty crappy...(I am no Audiophile, but it seems to me to be very tinny)...
By replacing the 1 way standard speakers (i.e the 2 x door speakers, and the 2 x 6 x 9s in the back)....with some quality 3 ways....will I get a better sound, or is the problem with the head unit/amp?
The way I understand it, is as long as I use good 4 ohm speakers, the sound quality will be improved?
Sorry for the n00b post, but I have no idea, limited budget, but am looking to get a slightly better audio result...
Cheers
Dean
Old Sep 24, 2008 | 02:04 AM
deanrx8's Avatar
Or is that 2 ohms for the back ones.???...god this is painful.
All I know is the sound is crappy. Want better sound, but not looking for concert hall quality...
Old Sep 24, 2008 | 09:13 AM
Socket7's Avatar
ಠ_ಠ
rear deck speakers can be replaced by just swapping speakers. door woofers cannot be swapped due to form factor and impedance. The front center channel can be swapped, but be ready to remove some material to makeit fit.
if you want to replace your door woofers you'll need to have an aftermarket amp
Old Sep 25, 2008 | 08:59 AM
Vyndictive's Avatar
"13B vs. Renesis" Discuss
Socket:
So if you have the bose system you can still upgrade your rear speakers without any ill effects?
Old Sep 25, 2008 | 09:13 AM
Socket7's Avatar
ಠ_ಠ
Originally Posted by Vyndictive
Socket:
yup. I had infinity kappa's in the rear deck running of the bose amp for months. I believe you can do all the tweeters as well. you should check the audio install reference . all the info is there.
Old Sep 25, 2008 | 10:37 AM
Vyndictive's Avatar
Yea, I've read through the reference.
I guess I just assumed the backs were some bose proprietorial nonsense just like the fronts.
Well, time to price out some 6x9s!
Old Sep 25, 2008 | 03:09 PM
firebirdude's Avatar
User and Abuser
Yup. Jedi has everything replaced except the 9" door woofers.
Old Sep 25, 2008 | 03:19 PM
never fear, Jedi is here!
Yup, you CAN replace the rear speakers, but the little guys require a little bit of custom work. (aka sharp razor blade and a steady hand)
garethleeds
Europe For Sale/Wanted
Nov 19, 2015 06:32 AM
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
Tsurugi
Sep 7, 2015 08:27 PM
nivong
Sep 2, 2015 07:54 AM
