Power Steering suspended 3 times in a month
Old Sep 18, 2008 | 12:26 AM
KL MFT's Avatar
Hi all,
I'm new to the forum. Any advice is appreciated. In mid Aug, I was driving my 04 as usual, but all of a sudden, the power steering light came on, and in maybe 3 seconds or so, the whole steering wheel got locked, got close to being entirely locked. I fortunately was running on a pretty quiet road, so there wasn't much traffic. I then turned off the engine and let it cool for a while. After maybe 3 minutes or so I started it back up, it was fine. I took it to the dealer the following day; luckily, they were able to verify the issue and supposedly "fix" it for me. However, 3 weeks and around 400 miles passed, the same situation happened, but this time was on a freeway. Again, I was lucky enough to be on the right lane, but let me tell you, it was one of the scariest things that can happen to people. So I took it in again, and they said they'd take a better look at the issue. They kept the car for a few extra days to work on it. They then told me that they removed the connector of the power steering system and this time should be fine. So here I am, wondering we if it ever happened again? What would be my options? Of course, I don't ever want to be in that similar situation again. Please let me know what you think.
Old Sep 18, 2008 | 01:57 AM
DaRotary's Avatar
wow thats hella dangerous....
Old Sep 18, 2008 | 01:58 AM
Originally Posted by KL MFT
Hi all,
yep,
it has happened and documented..
Old Sep 18, 2008 | 08:49 AM
clean the power steering connector, located RIGHT by where your coolant overflow tank's hose pointing at ...
Old Sep 18, 2008 | 09:19 AM
SideOfBacon's Avatar
^ clean it and check for possible wire corrosion. something aint right. definitely foreseeing a dangerous scenario.
Old Sep 18, 2008 | 06:20 PM
04RX8man's Avatar
Rotary Powered Countryboy
wow that does not seem safe at all but I would try as everyone else has said and clean the connector
Old Sep 18, 2008 | 11:45 PM
KL MFT's Avatar
I guess I'm asking more about options I have with the dealer in case it happened again. Of course, I hope I'll never have to go through that scary experience again. But if I did, should I be asking them to replace the whole power steering system? What would be reasonable?
Old Sep 18, 2008 | 11:54 PM
Jon316G's Avatar
Grasshopper
Replacing the harness (above the radiator fans, where they are telling you to clean) would be reasonable.
That's the connection that some of us have resorted to soldering together.
Billy Marcial
Mar 1, 2018 06:50 AM
uZu
Dec 30, 2015 12:35 PM
JakeKaminskisRacing
Aug 23, 2015 01:10 AM
SIllver
Aug 1, 2015 07:34 PM
CMRine04
Jul 29, 2015 02:07 PM
