Mazdaspeed Coilover Problems
Old Sep 9, 2008 | 12:05 AM
Mazdaspeed RX8 ver2's Avatar
Hey everyone, i installed my mazdaspeed coilovers awhile ago, already a month or so. I bought the coilovers secondhand from rockstar (former member). anyways, today i started having a heavy knocking for some reason while driving, and when me and a friend took a look, to my suprise that the shock snapped off the lower mount. The knocking came from the passenger side rear so we lifted the car and the shock is free, seemed like a clean snap off. how i found out it snapped off was while trying to realign the springs, a small cylinder piece fell on my head and after further observation, realized that the shock cylinder that mounts to the bottom support snapped off.
sorry i couldnt take a few pics, all i thought about was trying to fix this and it looks like i cant. the coilovers are warranty code orange and pretty much that means there is no warranty.
wondering what should i do about this? i contacted jason from onlinemazdaparts.com to see what help i can have. i'm wondering if there is anything i can do because right now, im so upset about the situation that i cant think. i paid 750 for these, maybe i got scammed? or maybe the engineering of the coilovers are just bad, either way, i dont have money to pay for a new suspension.... i have to revert back to stock but after installing a suspension.... man....
any help would be much appreciated... thanks
Jon
Old Sep 9, 2008 | 12:12 AM
Im not 100% sure which part u're taking about but, it sounds like you might be able to get a rebuild.
I have HKS HiperMax III, and I know unless I crush it, I can get a rebuild. they have all parts.
Try to snap a pic ...
Old Sep 9, 2008 | 12:19 AM
i'll see what i can do about the pics, let me see if i can find a pic of it or snap a pic of it. how do i go about getting a rebuild, when i bought the coilovers, i bought them used and it didnt come with all the parts, the coilovers are made by eibach and i had to pay another 300 to buy helper springs and spacers...
Old Sep 9, 2008 | 01:27 AM
#1 is pointing at the small shaft/bar that connects to #2 that's within the lower spring mount. so what happened is that number 1 snapped off the mount that is within number two, from what i could tell, its suppose to be one piece and welded or something within that mount, it snapped off and now that shaft (the content within that shaft is a small long cylinder that slides up and down shaft, the shaft is hollow. that small cylinder snapped right off. i had to install everything back together because i dont have time right now to try to fix it... i have obligations that are important to do... driving it, there is loud knocking and i believe right now, the that damper shaft is off its mounting point and resting on the spring mount....
Old Sep 9, 2008 | 01:35 AM
Blackmobile R3's Avatar
Bring that to mazda and threaten to sue them if they dont give you a whole new set. That could have caused a deadly accident.
Old Sep 9, 2008 | 02:02 AM
thought about that, will probably make an effort... im going to try to contact eibach themselves but most likely they will just tell me to call mazdaspeed...
Old Sep 9, 2008 | 07:29 PM
quick update, installing rear oem suspension, took pics of the broken shock, could be rust..
Old Sep 9, 2008 | 07:36 PM
Rust Never Sleeps..............
Old Sep 10, 2008 | 04:07 AM
heres some pics of what happened
this last image is what the "good shock" looks like that brought me to the conclusion of rust. let me know what you think.
anyways, i put back on the stock suspension on the rear currently running a "demon drop" look. really really sucks but atleast im safe for the moment.... if anyone has any advice for what i can do, let me know, apparently, me and and my friends believe that the previous seller drop this suspension in the snow causing them to wear down this much and the previous seller has been quite unreliable about this suspension do to the fact when i bought it, it was missing several parts and now i find out that he sold me a faulty suspension..
Old Sep 10, 2008 | 11:35 PM
not rust, but rather the shaft had a threaded part that screws into the lower mount and it appears to have fractured which allowed the two pieces to separate
I would notify mazdaspeed and eibach, but try to stay mum on being a secondhand buyer, most warranties only apply to the original purchaser
Old Sep 10, 2008 | 11:44 PM
Brettus's Avatar
Boosted Kiwi
wow - it looks like that thread is not man enough for the job ....
Old Sep 10, 2008 | 11:53 PM
It's strong enough for the actual spring/shock forces, but if somebody force-twisted on it trying to align the mount etc. or possibly overtightened it when putting the pieces together during the manufacturing process
I don't like the design in general. It's a low cost way to join the two pieces, but once it breaks or has thread issues the entire shock is f'd
when you bolt the shock into the rear tower mount you have to align the lower mount properly relative to the upper mount, the same as with OE type shocks, you can't just force twist the mount around to align it after the fact, the exception is if you have pillowball/spherical bearing upper mounts rather than the rubber bushings, then it is free to rotate wherever you need it, the rubber bushings won't allow it to turn easily enough
Old Sep 11, 2008 | 12:28 AM
what is a dspec for a 1000 alex.
opps did i say that. what do i know..
Old Sep 11, 2008 | 02:41 AM
i do thank you team for the help and i hope things get settled with this, i notified mazdaspeed and mazda already about this problem and they'll get back to me in a few days and i'll let you all know whats going on. thanks again for all your help.
Kahl
NE For Sale/Wanted
21
Aug 5, 2017 02:49 AM
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
LMURailsplitter02
Sep 6, 2015 10:56 PM
