Caliper Slider Seized!!
Well, this sucks!
I'm in the middle of a brake upgrade (rotors, pads, SS lines) and when I went to install the pads on the front driver'side I noticed the slider was not moving at all
can't get it out, wont' really turn either
I've now taken the caliper off and have soaked some penetrator on it to see if that will help remove the slider
I had this happen just last weekend, I didn't remove the entire caliper. I just sprayed some pb blaster on the slide, let it sit for 20 minutes and used some vice grips to pry it out. Problem once it's seized your really need to buy a new slide, the rubber seal inside is probably pretty f'd. I got my new one from Mazda, 17 bucks, but I found out Advanced Auto or AutoZone both carry the slide for a fraction of the cost. Be sure to use some brake grease when you install the slide again.
http://shop.blasterchemical.com/disp...?p=50003&pid=4
they got all kinds of other stuff too:
http://www.pbblaster.com/productlist.html
titaneum_grey
Sep 16, 2015 11:51 PM
badinfluence
Series II Aftermarket Performance Modifications
Aug 31, 2015 11:51 AM
