Advice - Ignition Coils
Old Aug 28, 2008 | 10:45 PM
ldr's Avatar
ldr
Hawkfan
I have a 2004 RX-8, and about two years ago the catcon went on it. Turned out to be the ignition coils were the problem, but it was all covered under warranty so I wasn't too concerned. But, a year later (last year this time) the same thing happened, and again it was the ignition coils... So, now a year later I'm now driving around wondering if/when the ignition coils are going to fail again... Anyone else experience similar problems? Should I replace the ignition coils to be safe, or consider my experience coincidence? Hmmm...
Old Aug 28, 2008 | 11:08 PM
J8635621's Avatar
Pew Pew Pew
Coils suck on this car as attested to by many forum members. Get the BHR yukon coils and then you don't have to worry about them failing anymore. https://www.rx8club.com/series-i-aftermarket-performance-modifications-23/bhrs-ignition-system-offerings-145128/
Old Aug 28, 2008 | 11:29 PM
our ignition coils are very prone to heat problems and I recommend they be changed every 20,000 - 25,000 miles
Old Aug 28, 2008 | 11:30 PM
Easy_E1's Avatar
BHR Coils are coming soon.
I know I've said that before, but it's true.
Old Aug 29, 2008 | 12:07 AM
ldr's Avatar
ldr
Hawkfan
Thanks very much guys, I appreciate the advice!
Old Aug 29, 2008 | 12:17 AM
ldr's Avatar
ldr
Hawkfan
If I were to replace my current coils with the Yukon's, should I also look at replacing the wires and plugs?
Old Aug 29, 2008 | 06:55 AM
alnielsen's Avatar
New custom cables come in the kit. The connector, on the coil end is different than the OEM. Replace plugs depending on their condition. You can get new plugs at Advanced Auto for about $80 per set. I believe BHR sells them for the same price and you can order them with the coil kit. As far as I know, this is the lowest price available on a set of plugs.
Old Aug 29, 2008 | 10:44 PM
suay's Avatar
Work hard Drive Hard!
Exclamation go with mazposrt
I have them now and you can feel the difference! Do not go cheap. The cheap stuff will cost u in the long run!
05TR1CH
Apr 18, 2023 04:56 AM
RA32425
Series I Engine Tuning Forum
10
Sep 8, 2015 08:53 AM
talonhart2
Aug 26, 2015 04:14 PM
madrotor
Jul 26, 2015 12:06 PM
thedragonrotar
Jul 22, 2015 08:46 PM
