Interesting Idle Vacuum Correlations PART 2
Old Aug 26, 2008 | 09:41 PM
MazdaManiac's Avatar
I've always felt that my idle vacuum was a bit too low.
It always came up a bit when I went to places with a bit less altitude, but there are other RX-8's here and their vacuum is higher. Even other MM turbo cars are higher, so its not the scroll, manifold or anything like that making back-pressure.
My current motor (and the one before it) ran perfectly and have good (or in the case of the current motor - crazy good) compression.
They are well-oiled and are totally normal in every way.
The idle is stable, smooth and regular.
There are no misfires, the ignition at idle is OE and the A/F is, too.
However, my idle vacuum is about 15" hg. It really should be at least 16 or 17 at minimum.
I tried going to a good set of stock coils (just to eliminate that possibility) and there was no difference from the BHR setup.
So, while charging my battery and flashing my PCM, I noticed something.
When I started the car, the current from the charger stayed in the 17 amp range!
When I stopped the motor, it dropped to 4 or 5.
Thinking that it could be something to do with my battery relocation, I moved the charger to the front of the car near the alternator and tried it again.
Same thing.
I tried a different alternator.
No change.
I spent several sessions with the motor chasing potential vacuum leaks with propane, carb cleaner and other solvents.
Its tight as a drum. No leaks.
I jacked up the OMP just to see the difference and, besides a ton of smoke, there was no change.
So, I am out of ideas.
Inspire me.
Old Aug 26, 2008 | 09:47 PM
paulmasoner's Avatar
Asshole for hire
where are you measuring from?
Old Aug 26, 2008 | 09:50 PM
Behind the TB where the VFAD used to be.
I verified it at the EVAP nipple like it says in the FSM.
Old Aug 26, 2008 | 09:53 PM
Asshole for hire
that was my only guess
Old Aug 26, 2008 | 10:36 PM
I gonna actually try pulling the alternator belt completely.
It might be an electrical load.
The only system I can think of that is only running when the motor is on that can pull that kind of current is the EPS.
I need to do some metered diagnostics to the wiring if it turns out to be electrical.
Old Aug 27, 2008 | 12:09 PM
Today is good.
Late afternoon?
Old Aug 27, 2008 | 12:17 PM
ponder this I shall.
Old Aug 27, 2008 | 02:54 PM
Nubo's Avatar
Lubricious
Air bypassing the throttle?
Idle rpm are normal?
I'm not sure about the battery charger thing; maybe just a red herring. Did you try that on another car? Maybe it's just behaving differently with the running engine due to voltage. It's trying to charge what it sees as a 15 volt battery instead of a 12 volt?
Old Aug 27, 2008 | 05:23 PM
No, that's a supercharger thing.
No "idle bypass" or anything like that.
Yep, totally normal, smooth, stead and no dips or anything. Like glass.
Yeah, I dunno.
An alternator load is the only thing I can think of at the moment.
The FSM says either a vacuum leak (which I cannot find) or bad compression (and mine is around 130 per combustion chamber).
So, I'm still stumped.
When it cools off this afternoon, I'll pull the alternator belt and see what happens.
Old Aug 27, 2008 | 06:07 PM
jeffe19007's Avatar
And is your idle lower than the folks with a better vacuum?
Old Aug 27, 2008 | 06:12 PM
Nope.
A bit higher, actually.
I have it set for 850 with my AccessPORT.
When I drop it to 800 (OE idle) the vacuum is about the same.
When I raise it to 900, it goes up ever so slightly.
Old Aug 27, 2008 | 06:15 PM
jeffe19007's Avatar
And is that with the air filter in place (guessing at a dirty filter)?
This is a new engine, so I would guess that there no defects after the throttle body that would impede airflow.
That's my two guesses. Next!.
Old Aug 27, 2008 | 06:31 PM
Fresh air filter.
New intake with bigger tubing, actually.
No change.
TB - exhaust ports are brand new.
Last engine behaved identically.
Old Aug 27, 2008 | 06:44 PM
jeffe19007's Avatar
I was hoping that the intake, being something, maybe, in common between engines was an answer.
Other than that, my old knowledge says the tune can affect the idle too. But I don't want to go there for fear of getting in way over my head!
Old Aug 27, 2008 | 06:50 PM
shaunv74's Avatar
Power!!
Maybe take a step back and list all the things that affect idle vaccum and walk through them 1 by 1.
Intake leaks
Intake restrictions
air density
rotor sealing
AC load
Alternator load
water pump
oil pump
Idle RPM
What else?
Old Aug 27, 2008 | 07:36 PM
What elevation are you located at?
Old Aug 27, 2008 | 07:57 PM
About 1200 feet.
Old Aug 27, 2008 | 08:36 PM
Brettus's Avatar
Boosted Kiwi
Try a AP underdrive pulley on that bad boy - runs for cover .......
Old Aug 27, 2008 | 08:41 PM
If there is a high load on the electrical system, that would just make it worse.
Old Aug 28, 2008 | 01:17 AM
did you not hard wire the eps? is there a fuse you can pull to isolate it in a easy way?
Old Aug 28, 2008 | 01:27 AM
I love simple suggestions!
Its nice, elegant suggestions like that which really float my boat.
It is so simple, I didn't think of it.
Thanks Swoope! That is what I'm looking for.
I'll go try that now.
Old Aug 28, 2008 | 01:32 AM
Asshole for hire
FSM says theres a 60A fuse on the constant power and a 15A fuse on the ignition/switched power to the EPS control module
Old Aug 28, 2008 | 01:39 AM
Asshole for hire
can you look at your PIDS/DTC
DTC B1318 is over/under voltage for the module
the PIDS might tell you something as well
C1099 - Abnormality detected in control current from EPS control module to EPS
motor.
Old Aug 28, 2008 | 01:43 AM
There are no PIDs.
But the 60A fuse is a no-brainer - its right on the battery terminal.
Gimme a sec - I'm working on AP calibrations.
I'll run out and test it in a few minutes.
Old Aug 28, 2008 | 01:58 AM
Asshole for hire
oh, lol duh.... this is why i have to touch things to make sense of them... i dont associate what i read with actual form/function very well sometimes
