Help on loss of power (LOTS OF LOSS)
Old Aug 23, 2008 | 11:39 AM
MICKY 3's Avatar
I have a RX-8, 2004, 231bhp, 6speed.........
ok when i set off it is like i have lost some power but when it hits between 4500 and 5000 rpm the engine noise changes (bit louber) and it gets a bit more power but still not the full wack...... i took the spark plugs out today and looked at then (full service less than 5000 miles ago) and they had brown powder on them, 2 coil packs have been changed and even if i swap them all round it is still the same.
anyone any clues???????
(oh and today i took off my trailing plug coil and it still funs the same)
i will love you forever if you know what is wrong with my baby and you will stop me from paying thr £67.50+vat to mazda for 1 hour of looking. x x x
Old Aug 23, 2008 | 12:14 PM
Condition of the plugs is normal.
Only thing I can think of is the catilytic converter.
You are getting more power.
Oh, try this. Re-set the ECU. that probably is your problem.
Old Aug 23, 2008 | 12:23 PM
Micky: might be a bad cat or it could be a bit of carbon build up.
You mentioned you only replaced 2 of the coils? Any reason you didn't replace all 4? If the other 2 are bad, that could be the problem.
Are you sure the spark plug wires are attached properly? They do have a tendency to come loose over time.
Old Aug 23, 2008 | 12:33 PM
MICKY 3's Avatar
only replaced 2 coils as it was mazda that did it but not 12month is up i have to pay for them. Plug wire's are on right and have checked and checked them.
The cat does sound like it has more noise coming from it if i lay on the floor and push the gas with my hand tho.
Old Aug 23, 2008 | 12:38 PM
MICKY 3's Avatar
And how do i re-start the ECU
thanx
Old Aug 23, 2008 | 12:52 PM
there's a brake stomp method or you can disconnect the battery. I believe the insructions are in the Tech Section. Search: Reset ecu
Old Aug 23, 2008 | 02:45 PM
I sent hom the link.
Old Aug 23, 2008 | 03:27 PM
MICKY 3's Avatar
done that and still the same
everything points to cat or coil's??????????
don't know what to do now lol
Old Aug 23, 2008 | 04:05 PM
i would pull the cat and look inside. it is pretty easy, and if it is bad it is obvious.
good luck.
Old Aug 24, 2008 | 10:21 AM
MICKY 3's Avatar
good luck.
Its being taken off tomorrow but what am i looking for?
Old Aug 24, 2008 | 10:26 AM
You will know It will either be in pieces...or all plugged up, or both.
Often the first section before the O2 sensor looks OK..but if you shake the pipe pieces will come out the other end. If you have access to a fiberscope that's an easy way to look up the back end
Old Aug 24, 2008 | 08:13 PM
MICKY 3's Avatar
well wish me luck am going in lol
Old Aug 24, 2008 | 09:07 PM
Easy_E1's Avatar
Be sure to put some lube on it.
Old Aug 25, 2008 | 07:02 AM
MICKY 3's Avatar
Thumbs up
Right a BIG BIG BIG thank you to.......... RAZZ1, JEDI54, SWOOPE and DONNOBRE for the info, i took the cat off today and empted out att the crap and dust and smashed the rest out. I've put it back on for 1 or 2 days till my new one gets here and all the power is back hehe
Yet again a ""BIG"" thank you to you all x x x
P.S. EASY E1 no lube needed i went in dry
Jesus Martinez
44
May 6, 2025 08:09 AM
Audio Concepts ATL
Sep 26, 2021 01:59 PM
uZu
Dec 30, 2015 12:35 PM
Espo
Aug 11, 2015 07:11 PM
Kim Jong Illest
Canada Forum
Jul 23, 2015 03:22 PM
